Question about RCA DRC8300N DVD Recorder/VCR
Dvd disk drawer will not stay shut
Vcr part works fine but when I try to put in a dvd it is ejected over and over,even does this when no dvd is in it. Any help would be appreciated.
  • 550 Answers
There is an obstruction in the back of the drawer slot, when the moving drawer strikes the obstruction it reverses. usually lint or pet fur, it can often be vaccumed out through the drawer with a micro adaptor
(xbox360 are notorious for this, if you open the case to clean the **** out MS void the warranty)
or tby opening the case and vaccuuming
Posted on Sep 10, 2008
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
How can I get my DVD to get unstuck out of my VCR/DVD player?
I can't get any support from sansui. I think your DVD player is trying to read the disk. It can't and its stuck in DVD mode. This is just something I would try I don't know if it will work. Unplug the power source hold down the eject button and plug it back in. The objective is to try to get it to spit that disk out before it has a chance to try to read it.I hope this helps. If it does give me a vote and I'll know it worked.
Mar 04, 2010 | Sansui VRDVD4001 DVD Player/VCR
I put in a DVD and will not go beyond "loading". disk door will now not open. The VCR operates just fine.
sounds like a bad pickup laseror it might even be dirty I would try to eject the disk if it does not want to eject I would do it manually by take the top off and taking the disk out then try to open it again if it does not seem to move then the motor on the ejector might be stuck or bad. First I would check that run a good cleaning disk and see if that helps if it does not looks like you have to make a decision to repair or replace the unit.
thanks please do rate the solution
Dec 29, 2009 | Samsung DVD-V4600 DVD Player/VCR
Dvd eject problem
The drawer on a dvd player is a rack and gear drive. Sounds like you may have a bad motor or a jammed drawer. If you take it a part, see if you can find the motor that drives the drawer. It should have a worm gear on it. Try to turn it to release the drawer. It maybe out of time or slipped a tooth on the gear, hope this helps
Oct 20, 2009 | Sony Televison & Video
Dvd recorder /vcr combo
possibly what has happened is the disk is not lying flat in the drawer, and is jamming as you try to remove, otherwise it could be a mechanical failure of the tray itself.
for the first you could try turning the unit upsidown, shake gently, and then put the right side up and try to eject drawer, if there are any rattling noises when doing this it may be that the disk failed in the drawer(broken into pieces),
if this does not help , you may need to dissasemble your DVD drive to recover your disk and reset the drive mechanism. only do this if your machine is out of warranty
Oct 15, 2008 | Televison & Video
Sony DVD RW DRU-820A
HI,
Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
Finally try the drive without a disk in ( open/eject Or Close )
Mike @ Compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Dvd player not working
the disc may be jammed. try using a paper clip straightened a bit and insert into the little hole in the front of the dvd door. that should release the dvd drawer. if the drawer can not be pulled out because of a disc jam, you can try to close the drawer again and gently shake the dvd player side to side, front to back to jostle the disc back into the tray/drawer. then try the eject button again. failing that, you can try to remove the outer case and that ought to give you access to the disc, and allow you to see where it is relative to the tray.
try that and let me know how you are progressing with this problem
good luck
mark
Dec 29, 2007 | Televison & Video
RCA DRC8300N DVD Recorder/VCR Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
