SOURCE: Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
SOURCE: I need a manual for a smeg dishwasher model No:
Not sure if this helps - I could only locate the manual for SA683. These might be very generic manuals and you should get the information you are after.
http://www.smegtech.com/site/smeg/pdf_libretti/19390059400-GB.pdf
SOURCE: My Bosch dishwasher model no
this sounds like a motor failing and its using to much power cusing the fuse to trip .. it may need a motor . but do try using a cleaner in it and it could correct the problem . like dishwasher majic / or jet dry cleaner for dishwasher / or even glass majic .. these will help mm . hope this helps the problem .. mm
SOURCE: smeg dish washer mod. dw1612c pumps
could be a problem with the pressure switch which will need to be replaced.
The part is available from this place.
SOURCE: Moved into new house with
http://kitchen.manualsonline.com/ex/product/headline/m/smeg/d/dishwasher/p/SA425
I found a site that has many, many manuals for Smeg Dishwashers. None are what you asked for. Perhaps you have the wrong number.
Check the site out, maybe there is one there that will match your machine. Good Luck.
