Question about Cyberhome DVR 1600 DVD Recorder
No disk read what u said about the CyberHome DVR 1600 is it the powersupple on the dvr 1200 mine will not load movies but will play music cds
HI I have this problem too - I opened the back of the unit and disconnected the DVR 1600 tuner and inserted a DVD and the unit was able to read it. I wanted to record a show so I inserted another DVD+R and when I got the message "no disk found" I attached the cable to the DVR 1600 - turned the unit off and on and disconnected the cable again - fed in the disk and it asked to be formatted. I think the problem is in the DVR1600 tuner module found at the back of the unit in the middle
Posted on Sep 21, 2008
    Problem Solver:
  • 3 Answers
Hi. I have this problem with my unit. After a lot of research on the net it apperars that this is caused by problems with the laser pickup. The laser is either dead or is on its way out and doesn't have the strength it needs to read sensitive DVDs but is OK with Audio CDs.
A lot of CyberHome units have this problem due to the poor quality of the laser pickup units they use. I have been told that they have since gone bankrupt. If it is still under warranty then it you may be able to get it repaired but otherwise it may be cheaper to get new unit.
Hope this helps
Posted on Sep 12, 2008
Cyberhome dvr 1200 doesnt read disc
its lazer is either burned out or too dirty to read the information on the disc try putting a lazer head cleaner through it
Apr 20, 2010 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 1200 dvr
First the Dvr 1200 has hard ware failure in it the tray eject unit and the display is failed ........................................it can fix in local service center.............................
Second your New DVR 1600 check the format of the dvd is it compactiable with format of the player and if face the same problem get it replaced as this is new player manual opening could lead no warranty on the player , it better to get it replaced ..
May 30, 2008 | Cyberhome DVR 1600 DVD Recorder
LOCKED DVR
I just bought the CH-DVR 1600 @ Target. This is just a temporary workaround to enable playing of region 2 DVD disks (don't have other regions but believe it will work also), until the real regional unlock is available.
1. Insert the region 2 DVD disk and close the tray.
2. Wait for the "Wrong Region" popup to appear in the upper-right corner of your TV screen.
3. The display on your DRV reads "STOP" at this point and the "Wrong Region" popup has disappeared.
4. Press the number "1" button on your DVR remote and a small input popup will appear in the upper-left corner of your screen.
5. Do not press anything else and the DVR will accept this entry as a chapter # and proceed to this chapter to start playing the movie.
NOTE1: The DVR runs in a somewhat restricted node, e.g. the DVR display still reads "STOP" and some remote functions do not work, such as "Menu". The input numbers correspond to the chapters on the DVD disk, so you can experiment and get to the menu once you hit one of the extra feature chapters with a "back to the menu" link on it.
NOTE2: I’m anxiously awaiting the real unlock sequence, as I tried most of the old ones posted here, none seemed to work.
also try this
-Switch player ON with no disc in the tray. Close tray and press MENU, 1, and 9 on the remote control. A menu should appear with the Region Option. Highlight the Region entry and press ENTER on the remote. Type in the Region you want. (Put 0 for code free) Press ENTER again to confirm choice. Press OPEN/CLOSE TRAY button and put in movie.
Mar 31, 2009 | Cyberhome DVR 1600 DVD Recorder
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 1200
I have a cyberhome 1600 dvd recorder and I need a code to program it to my bell remote but can not find any codes for the cybehome. can someone help with the codes
Nov 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 1600 DVR Format problem
Heat related.  Google "Cyberhome DVR-1600" "power supply" (with the quotes included) for answers...or look elsewhere in this forum.
Jun 30, 2007 | Cyberhome DVR 1600 DVD Recorder
No Disk
cheke rotation of the disc .suppose it"s slow speed or not rotate change the motor . before do this make sure the tray is in loading position . if ok proced the above suggetion. if not check the tray loading motor, belt and related things best of luck do with care by.
Jun 14, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVR 1200 acting up; won't format new blank dvds; says no disk,etc
Cyberhome has gone out of business in the US. My DVR 1200 stopped working but I was able to repair some capacitors on the power supply to get it going again. You can find more support information about the 1200 and 1600 on these websites: http://cms-system.cyberhome-dvd-help.com/modules.php?name=Forums&file=viewtopic&p=14183 or www.nerd-out.com and search for Cyberhome.
Jan 02, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVR 1600 DVD Recorder Logo
211 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
