Ricoh FT 6665 copier
What is the problem with my Ricoh FT 6665 copier for service call sc547?
  • 2,794 Answers
Zero Cross Signal Malfunction.
Fusing/Hot roller temperature does not increase.
The fuser rollers need to be inspected.
Posted on Sep 10, 2008
  • Tim Babcock
    Tim Babcock Sep 10, 2008
    You will have to replace the fuser rollers to clear the error code or replace the thermistor.
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
Jun 19, 2013 | Ricoh Aficio 450 Copier
Ricoh afico 811 error sc689 and sc547
sc547 is a power supply error that can mean you have a faulty power supply. The service manual does not list an sc689, and it's not in the help desk support database either... are you sure that's the code that comes on the screen?
Oct 05, 2010 | Ricoh Aficio SP C811DN-DL Printer
Eror sc547
The error sc 547 refers to a "Zero cross signal malfunction".
This means that the applied power supply AC frequency was detected at over 66Hz or below 45Hz, and the zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible causes are:
- Power supply board defective
- IOCSS defective
- BICU defective
Try to reset the SC code by entering SP5810 and select 1.
Then hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, try to replace the Power Supply Unit.
Jul 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Error sc547 aficio 180
Heat up failure in fuser area. Have tech check thermofuse and thirmistor for signs of wear or dirty
Jan 12, 2010 | Ricoh Aficio 150 Copier
Error code facsimile error red wrench sc547 ricoh aficio 180
there may be a problem with your electric supply(wall outlet) , wrong voltage or power supply bad
Jan 07, 2010 | Ricoh Office Equipment & Supplies
Ricoh afficio color 6010
· Hot roller fusing
lamp brown
· Hot roller
thermofuse opened
· Defective main
control board
· Defective I/O
control board
· Defective AC drive
board
more than likely the thermofuse.
Jun 17, 2008 | Ricoh 6513 Copier
SC547
try to replace power supply
Apr 24, 2008 | Ricoh Aficio 1085 Laser Printer
SC547
Press clear modes, 1, 0, 7, and press and hold the clear/stop key. Enter copy sp. Select mode (5), and scroll to 5810 if it exists, and execute. exit back to the copy sp screen. Press data log (7), and scroll to 7807, and execure. Exit all the way back out to the SC547 screen. Turn the power switch off and on. Not the button on the control panel, but the actual switch. If it comes to ready, great, if not, there is somethong wrong with the fuser.
Ricoh copier
Must have unplugged the thermister on the coupling connection bank. Reset fuser: Clear modes/ 107/ press and hold clear/stop. Pick copy sp. select mode. exit out of all screens and cycle power.
Feb 21, 2008 | Ricoh Aficio 450 Copier
168 people viewed this question
jasbo
jasbo
