Question about Actiontec (GT704WG) Router
Actiontec MI424 and Direct TV DVR
I cant figure out why but my DVR is hooked up through an ethernet cable to my router. The DVR says is has an IP address (so it must see my network) but its unable to connect to the internet so I can access the on demand stuff. I'm guessing I have to change my router settings, but verizon and direct tv both say I have to talk to the other. Can someone please help?
James
  • 7 more comments
  • pilotjames Sep 10, 2008
    My router IP 71.182.140.27
    DVR says IP 169.254.87.175 Subnet Mask 255.255.0.0 Default gateway (blank) DNS (Blank)
    Mac Address 00:19:DF:8D:45:9C
    Thanks in advance for any help
    I should add that I'm not really good with computers, so I would be greatful for plain lauguage and baby steps
    Direct TV HR-21 DVR
    Ok, I tried the advance setup and tried to change the IP address in the DVR, but I cant hit connect. Do I have to fill out the other fields as well, like subnet mask, default gateway, dns, and mac address? If so where do I find that info. It does say its connected to the network just not the internet. Thanks...
    James
    OK, i put in those settings, it let me select connect. It said OK in all fields (IP, subnet, default gateway, DNS). It still says its connected to the network, but not the internet...any ideas?
    also, the what do you mean by the stars in the IP? i just put 71.182.140.27 is that right?
    it says internet explorer cannot display the webpage
    windows XP...still no luck
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the IP address of your router?
    What is the IP address of your DVR?
  • 2,794 Answers
Your DVR need to be set at 71.182.140.***  *** meaning an available address.  Then they will connect.
What is make and model number of the DVR?
Posted on Sep 10, 2008
  • 1 more comment
  • Tim Babcock
    Tim Babcock Sep 10, 2008
    Your DNS should be 255.255.255.0.
    Your gateway should be 71.182.140.27
    I wonder if that gateway address should be the IP address assigned from Verizon.
  • Tim Babcock
    I don't think that the gateway address.  What happens when you type in 192.168.0.1 into your internet explorer browser?
  • Tim Babcock
    71.182.140.27 I bet is the DNS.
    What operating system are you using?
Can you run a seperate router for your dvr and another one for computer wired connection
It's hard to tell exactly what you have but it sounds like you have DSL on the 2wire. If everything is hard wired you can use the LAN Ethernet ports on the Belkin as a switch. You should to assign a static IP on the Belkin for management purposes and shut off its DHCP server. The static IP should be something in the range assigned by the 2wire but out of its DHCP range. Like 192.168.0.5 You will not need the WAN port on the Belkin. After you reconfigure the Belkin connect the Ethernet port on the 2wire to it. Along with your PC and DVR. I think it has 4 LAN ports so that will leave one open. It would probably be easier to buy a switch at the store.
Dec 15, 2013 | 2wire (1000-400108-001) Router
Can any one please tell me how to connect the DVR to router in simple way. Please
Ethernet cable is the easiest way. If you can, run a cable from your router to the DVR. This may require buying an extra long cable. Once you make the connections, just restart the router and DVR in that order, your IP info should show up on the broadband set-up page, found in the DVR menu. If your router requires a password to access the network you will have to enter that into the DVR settings after the connection is set up.
If running a long ethernet cable is not practical you may find it useful to try a Home Plug device. Just follow the manufacture's instructions. Alternately, a USB wireless device that plugs into your DVR can be used. You will need your wireless security info to complete the connection.
Oct 11, 2013 | Computers & Internet
How to hook up tv with internet hard wired to existing router with wireless connection to computer ip address on computer will not connect tv to internet help
Assuming that you have an "IP" TV, run an Ethernet cable from the TV to one of the LAN ports on the router.
Run another Ethernet cable from your computer to one of the other LAN ports on the router.
Both the TV and the computer should now have Internet access.
Do you have a third computer that has a "wireless" connection to the router?
Sep 26, 2010 | Belkin (F5D7230-4) Router (587009)
We switched from cox Cable to Direct TV. The BD390 works normally through an Apple Airport Express with an Ethernet connection to a Motorola SB 6120 modem. The system does everything it is supposed to...
So practically you want to use the BR390 as an access point, to route the data from the Apple to the DVR. No, this isn't possible since the player doesn't have routing capabilities.
But you can do something else: instead of the Apple (which is just a very simple router with some minor extra capabilities sold ad an outrageous price) you could get a way better normal router for a lot less than $100 and connect all devices thru LAN cables in an local network.
Aug 17, 2010 | LG BD390 Blu-Ray Player
Wireless Internet Issues
USERNAME:admin
PASSWORD:password or password1
That is the default user/pass, if it has been changed from default, you will have to reset the router and then use the defaults I gave.
Mar 31, 2010 | Actiontec Electronics (GT724WGR) Retail...
We are having problems with our wireless internet router. We have the WEP key and the wireless web name. The model is and Actiontec MI424-WR. How do we either figure out the password or how to log-in to...
donot enter http before those numbers...just type that number alone in the browser and log in to router....there below the wireless option you can see the security key for your wireless network....
Mar 31, 2010 | Actiontec Computers & Internet
Verizon modem/router and Netgear WGR614v9 On Demand setup
  • the modem and router must connected
  • either you use a long ethernet cable to connect the tv to the router or use a powerline to extend the router.
Jul 31, 2009 | Actiontec (GT704WG) Router
Actiontec router
Move the second camera to just a few feet of the AP. After setup you can move it back out.
Jul 06, 2009 | Linksys Wireless-G WVC54GC Network Camera
Actiontec GT701-WG doesn't recognize a DVR on the LAN
I think the screen you may be looking at is the Application layer forwarding screen, the drop down box being populated by DHCP clients, that's why it isn't seeing the DVR. The DMZ Hosting screen doesn't have a drop down box, it only requires an IP address to be entered.
Hope this helps!
-Backu
Jan 16, 2008 | Actiontec (GT704WG) Router
Actiontec (GT704WG) Router Logo
533 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
