Question about Mitsubishi WS-65809 65" Rear Projection Television
WS-65809 ERROR CODE 22
I RAN THE DIAGNOSIS AND IT GAVE ME THE 22 ERROR CODE. WHAT DOES THIS TELL ME
  • Mitsubishi Master
  • 8,617 Answers
Look on the center circuit board and you will see two green Pico fuses they look like resistors but they dont have any bands on them . They will have F9A04 and F9A05 on the board next to them. Check with a ohms meter if those fuses are open you will ned new convergence ICs. Thats the first thing to check are those two pico fuses when you get a 22 error on your model.
Posted on Sep 10, 2008
Mitsubishi ws-65809 powers on for 2 seconds. After holding menu & input I get a 1 blink, 2 blink error code. Anyone know what this error code is and how to fix. Thanks
2,2 error code is short protection---98% of the time it means one of the two soldered in pico fuses this set uses is blown----there are several---but your problem means if it is ws-65809 one of the two stk-392-570 convergence chips has failed.
I will attach a photo---they are on the middle circuit board and the two to the right are for convergence--both are green and 5 amp--with the set unplugged check both of them like any fuse--no reading means bad.
If you find this--I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET--SHOPS WILL GET 300 or more but you if you can do it yourself buy everything you need for under 40 dollars--I can tell you the best place to get the chips, fuses, etc.
If you want the instructions let me know and I will post them here for you---they are based on my own actual experience doing this repair in this kind of set hundreds of times.
If this information helped you rate this solution as I do this here for free.
SD TECH
Here is a photo of what the two chips look like--The one in the picture says 392-560 but yours uses two that look just like it--STK-392-570.
Dec 28, 2009 | Mitsubishi WS-65809 65" Rear Projection...
TV TURNS ITSELF OFF
If the WS-65809 comes on and then the power light goes off---do the self check this model has:
When the light goes off on the power button----on the front of the TV press both the MENU and INPUT (or device) buttons at the same time and hold them for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code--for example--2 blinks, a pause and 2 blinks--this is the most common error code and costs the least to fix.
Let me know what error code you find and I will tell you what it means.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 16, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Turns of after being watched for several hours.
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Oct 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I have a Mitsubishi ws-65809 when i turn it on it shuts down after 2 seconds, i held the input and menu buttons in and it gave me cod 2-3 was wondering what could be the problem, and if it is an easy fix...
Error code 23 means "Loss of Horizontal Deflection" that means horizontal section of TV is not working. Cause can be horizontal out transistor is short or not getting +B volts from power supply.
If you understand schematic, I can email you complete repair manual of Mitsubishi WS-65809 that will help you to diagnose problem by measuring volts and checking parts.
Thanks.
Sep 15, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Ws-6580 error code 23
CODE / INDICATES
12 / No error has occured
21 / X-Ray Protect Shutdown
22 / Short Protect Shutdown
23 / Horizontal Deflection failure
24 / Vertical Deflection failure
Aug 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Powering up tv
its most likely has a 22 error blink, if menu and device are pressed together and held for 5 seconds to activate the self diagnosis feature. which would indicate short protect.
Sep 08, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Error Codes
SQV is a setting under the Channel edit function in the setup menu. Your model doesnt have the on screen error. What you do is next time it shuts down you have to press input and menu on the sets front panel both in together for 5 seconds to see if the LED will blink a two digit error code.
Jul 17, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Error code 22 on a Mitsubishi WS-55907 55'' HDTV
your set is the V17 series so a code 22 means short protect. Which means the TV has a short circuit condition and is shutting down to prevent further damage. You can get a manual for the V17 sereis at the following link for 15.99 and they will provide free unlimited support to help you with the diagnosis and locating parts. Your set is coverd in the V17 sereis service manual under the mitsubishi section. Here is the link in case youd like the service manual and free support.
http://servicemanuals.vstore.ca/
Mar 08, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
779 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
