I just bought a used Mitsubishi WD-73727 DLP TV. After watching it for about an hour or so the set turned itself off and the Lamp LED came on red. Going through the diagnostics, I got a code 34 (Abnormal Lamp). I'm now thinking I have a burnt-out lamp. I reset the TV and in the following morning tried turning on the set. It powered-up with no problems and seems to be running fine. Of course, I only had it on for 5-10 minutes. Is it the lamp? Should I replace it? Could it be something else, since the TV came back on? I got a REALLY good deal on it and if I have to spend $200 for a lamp I'm still ahead. If it's something major, I want to return it ASAP. TIA!!
  • cptgrey Sep 12, 2008
    Tim,
    Thank you for your advice. When I contacted the seller, I was told that a new lamp was just placed into the set. I'm declining to keep it and will trade it out for something else.
    Thanks again!
    Bests,
    Cpt Grey
  • RICO78 Mar 17, 2009
    (RICK 78 )I HAVE MITSUBISHI 73727 AND AFTER WATCHING IT FOR ABOUT 15 TO 20 MINUTES IT TURNS OFF AND RED LIGHT COMES ON IT SAYS( LAMP )I WAIT ABOUT 30 SECONDS IT COMES ON AGAIN I JUST BOUGHT IT IN AN AUCTION AND I DO NOT HAVE A OWNERS MANUAL. THANKS FOR ANY HELP
    Novelist:
    Champion:
  • 203 Answers
There are a few things that could cause this. The lamp is the most common but I have seen some other werid thing cause this problem (ballast and engine) changing the lamp would be a good way to "shotgun" the repair but if you want to know for certain you will need to call someone out that can troubleshoot it the right way. Good luck and if you need any more information please let me know.
Thank You
Tim
Posted on Sep 11, 2008
How do you know if your lamp is out. there is still light on in the back of the tv
An LED indicator on the front panel of your TV will blink even you have light in the back panel of your TV this LED indicator will remind you if the lamp must be replace because DLP projection has a lamp hour meter the lamp time for this DLP 6000 to 8000 hours.
Sep 23, 2011 | Mitsubishi WD-62526 Projection TV
I have the Mitsubishi WD-65738 65-Inch 3D DLP HDTV I was watching it and it made a pop sound, then the screen went black what can I do.....
Tv "LAMP" LED light indication on the tv frame word light up or blinking LED light.Check the tv projection Lamp first.The tv projection Lamp might litterly broken into glasses sharts itself.The tv projection lamp still intact,still should be change too though.After the tv projection lamp has been change the tv should work now.If still have problems the board that call the Balast board probally dead too.Becauuse this Ballast board only jobs are to help to ignite and keep tv projetion lamp light up and to work only.
Sep 01, 2011 | Mitsubishi WD65737 65" DLP TV
I have a mitsubishi the model number is wd-82837 it keep shut down after blue screen show
Ur tv"LAMP"LED light indication flashes or stay on?Ur tv projection lamp been inside this tv like a 1 1/2 or 2 years and tv been on an in used like 4 or 5 hours every day.Yes to all of this,than the tv projection lamp is the causes and it life are ending.The tv projection lamp require replacing.
Dec 09, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
My lamp on my Mitsubishi WD65733 DLP TV actually blew up while I was watching it (kablooey). So, I bought a new lamp and replaced it. Now, the picture and sound comes on for about 30 seconds then it turns...
No check for bad capacitors on Power supply board they will be vented swollen or puffed up on top.
Go to Encompass Parts Distribution and look up your Model number.
May 09, 2010 | Mitsubishi WD-65733 65" HDTV
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Feb 02, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
Electro Med Services...
