Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
Turns blue and has shadows
Its fine when you first put on after a few minutes,top left corner gets bluer and lines start to shake and you can see shadows of the picture...
  • Sony Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a comturns blue and has shadows - 2c07611.png.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from
www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 22, 2009
    Scholar:
  • 60 Answers
You guys are awesome! I picked up one of your kits and fixed my TV in less than 1 hour. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Posted on Aug 19, 2009
  • James120 Mar 12, 2010
    Just checking to see if the solution above worked!
I droped it =( 1- when i start the camara , i hear a shake or rarel in the zoom 2- in the digital view finder i see the image shaking 3- than it finally stops the image shaking right to left very...
Sounds like your image stabilizer got damaged by the fall. You'll have to get your camera serviced by an authorized Nikon service center.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Nikon COOLPIX P90 Digital Camera
There is a faint background shadow covering the
remove toner/drum unit from the printer. remove toner from drum unit and shake toner cart. side-side to loosen toner inside. On top front of the drum unit there is a purple/blue button that will slide right-left. Do this a few times to clean the wire. If there's a lot of loose toner, take a vacuum and clean carefully. Put everything back inside. With front door still open, hold GO/Control button down until all lights have lit, then let go, close front cover.
If you still have the shadow over the page, it's most likely the toner cart and you need to buy a new one (or recond.-refill) at someplace like Office Depot or Staples.
Jan 20, 2010 | Brother HL-2040 Laser Printer
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
Philips Blue Shadowing
If you have not already done so go into the picture menu and set the convergence. The convergence is the angle at which the three picture tubes meat at a given distance. The tv will have at least 3 and up to 64 convergence points, and those 64 can be set for all three colors. This can be tiresome but I'll be it will solve your problem. What your trying to do is get the color in the cross-hair so you cannot see the color behind the target. On top of the fine setting for each point and color you will probably have 3 gross adujustments for blue and green and maybe red. These adjustments will affect positioning, like what you are discribing. You should do this at least every month, the thermal cycleing of the lamps is what will cause this to creep out of adjustment.
Sep 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Growing Blue Shadow
Hi, please try to replace the cable, try another input source and reseat or replace the bulb . If issue still present upon doing those steps you may need to call epson tech. support at 562-276-1300 so that they can verify whether your projector is under warranty or not and give some great option regarding your projector.
Tirzo
Jun 05, 2008 | Epson EMP-740 Multimedia Projector
Monitor has shadows from left to right
Try changing the cable that connects the monitor to the computer, that might improve things slightly, but because you said that it works for the first 15 minutes I'm skeptical that the cable has anything to do with it.
The monitor is near the end of it's life. There's not much that can be done.
Jan 24, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Hitachi 53SBX10B
It sounds like the lamp is failing.
Jan 06, 2018 | Televison & Video
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
