Question about Minolta magicolor 2200 DeskLaser Printer
While making copies the middle letters are smeared
  • 210 Answers
Could be a problem common with whatever your specific printer is. However, if it is a laser printer, it is a problem with the fuser not getting hot enough. Try having the thermostats attached to the fuser unit checked.
Posted on Sep 11, 2009
RICOH 1224C COPIES ARE SMEARED
Smeared output can also result when you refeed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
If this does not resolve your issue then make sure the fuser is heating; if not, the thermostat is bad and you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
May 12, 2010 | Office Equipment & Supplies
Canon iR2016 PCL5e A4 copies have suddenly started to print out in landscape, regardless of any buttons pressed. This means all copies are coming out portrait shape but only printed across the middle. Any...
Check and make sure the paper setting is on what it thinks it is. In other words, make sure the the paper in the tray is letter and the display says letter, instead of letter-r (letter-r runs the long way from side to side in the tray, and letter runs the long way from front to back in the tray) or any other size. I am not familiar with the set up of the paper trays on that machine, but if you have to program the paper size yourself, make sure it is what it is.
Oct 27, 2009 | Canon iR 2016i Black and White Copier
I have a problem with ink smearing on Southland fine linen paper on letters I've sent out The letters are folded in three and put in an envelope. The reciepients are recieving the letters with smeared...
Sometimes it's due to low fusing temperature. Certain papers need higher temps. Check the paper supplier or look in the printer setup menus and adjust the paper type to as close as possible to what you have.
Oct 23, 2009 | HP LaserJet 4250n Printer
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
When printing the printer is leaving smears on the left side of the page and random letters. If I make 20 copies, the first 5 and the last few will have the marks. I already changed the drum and all...
you need check
1) you may make sure the smear occur after the photo drum unit or after fuser unit, you can stop printing when the paper goes around between the drum unit and fuser unit,
2) clean or change fuser leaner if the random smear occur after the fuser unit(not after the drum unit).
3) still check new drum unit there is a cleaner on it, it could be the smear occured if not enough cleaned drum surface
hope you fix it
May 06, 2009 | HP LaserJet 2840 Printer
My copier smears the middle portion of printed documents.
Cleaning the roller (drum) may have made things worse. You will need a new toner cartridge. However you should try and get a replacement from your supplier if the cartridge is not too old
Jan 02, 2009 | Canon imageCLASS D661 Digital Printer
Ink smears ,
You need to clean the print head until the smears clear up
Dec 15, 2008 | HP Deskjet F335 All-In-One InkJet Printer
Printing is smeared
Replace the black ink cartridge
May 13, 2008 | HP PhotoSmart 7760 InkJet Printer
Minolta magicolor 2200 DeskLaser Printer Logo
42 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
