Question about 2wire 2700HG-B Router (2700HGB)
Laptop doesn't read 2701HG-B 2wire router
My wireless laptop doesn't read the router. I just received it and it was connected but my wireless computer cannot detect it why?
  • Chrispy73 Mar 12, 2009
    im having an extremely similar problem but my biggest issue is that when i go to set my SSID my wireless section is missing and I have the same gateway
    Novelist:
  • 143 Answers
Make sure that the wireless part of the router is enabled by logging in to the router's page. check if the wireless light is on. try to customize the wireless settings like changing the wireless name (ssid) and the wireless channel to prevent interferences.
make sure that the wireless adapter/card of the laptop is also installed properly.
hope this'll help you and just ask me if you have other concern
ciao!
Posted on Sep 10, 2008
Can't add my new laptop to my at&t 2wire DSL.
Have you done a network search with the laptop? Is wireless activated on the laptop? Have you reset router? Plug the actual network cable to configure the laptop first then, once you do that, it should be recognized by the router, some router models requiere you to do this before you can connect to them wirelessly...
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
How do I add additional devices (laptop computer) to the router?
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
note: 2wire is already a wireless router / modem need for other modem to have a good network at home
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 09, 2011 | 2wire (2701HG-B) Wireless Router
I am connected to the internet but through the ethernet cable. The wireless on the modem isn't working. My laptop wireless is but i cant connect without my cable. Please help :)
Wireless light ont he modem would only lit up once a device had succesfully connected to it:
what is the operating system of your laptop?
you can also Try this links: complete walkthrough and screenshot is in the link... thanks...
if your with AT&T try calling this number
Aug 08, 2011 | 2wire (2701HG-B) Wireless Router
I want to know if my 2wire 2701HG-B supports WPS or AOSS? I'm trying to connect my laptop to my wireless printer but it goes through a Wireless Network which is my 2wire router obviously. If my router...
As long as you do not have your laptop set up on teh 2701HG-B's DMZ everything should work. I have the 2701HGV-B, almost the same except my can do VoIP, and I have my laptop running wirelessly and I can connect to the network printer.
Make sure the printer has a static IP address for your local LAN, which should be in the 192.168.X.X scope, or the printer will change IP addresses every time it resets and that will cause you to lose connection to it from the laptop.
As for WPS, there should be a sticker on the side of teh 2-Wire that has a 6 digital key number, all numbers no letters, that will be the WPS key.
Hope that helps.
Jun 04, 2011 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire xbox 360 wireless
My 2 wire is a home portal 1000 which doens't have wireless. So the easiest way to solve this is to get a wireless router and plug it into your 2 wire router (I did this) then connect the xbox 306 to that.
Sep 24, 2008 | 2wire (1000-400108-001) Router
Can't connect 2wire to internet
Before router put usual low cost switch....
May 21, 2008 | Computers & Internet
2wire 2700HG-B Router (2700HGB) Logo
179 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
