Question about Garmin nuvi 200W GPS Receiver
Making more room on my Garmin
I have done everything suggested by Garmin tech support to make more room on my unit.  I have deleted voice files, text files, and jpegs.  However the preloaded jpegs still show up on my Garmin.  No matter what I try I can't create more room for another map.  Is it possible to delete the current map?  Should I just reset my system?  I'm stumped!
You have to delete the old maps in order to install the new ones.
Posted on Sep 25, 2008
How do I delete maps from Garmin Nuvi 765
Connect the Nuvi to the PC with the supplied USB cable. After about a minute, the computer should recognize the Nuvi under Windows and assign it a drive letter. Double-click on the drive letter and view the directory in the Nuvi. Look for a subdirectory labeled "Garmin". Double click on the Garmin subdirectory. Look for the file named "gmapprom.img". This is the map file. This will be a very large file, around 1GB. I would suggest making a backup of this file on your PC in case a future map upgrade fails. Once the file is backed up you can go ahead and delete it. You have now freed up memory for a new map. You can also delete unused voices in the voice subdirectory. to free up additional memory.
Apr 06, 2014 | Garmin nuvi GPS
Garmin nuvi 610 memory full
You can attach the unit to your computer and then delete some information like extra voices, languages, help files, pictures, etc. You can also delete from the gps menu old locations and favorites.
Make sure you make a copy of everything first before you delete anything.
Thanks for using FixYa
Aug 23, 2011 | Garmin Nuvi 610 GPS Receiver
My Garmin C 330 has completely lost its voice. Everything else is fine. Any suggestions?
try Tools.... Settings....Language.... under Voice tab select one that ends with ( TTS ) text to speech....
Nov 27, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi250W says NO DETAILED MAPS FOUND THAT SUPPORT ROUTING!
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
Regards,
Richard.
Mar 30, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Memory full
****HELPFUL HINT**** Before you do anything with the Garmin unit, you might want to make a folder somewhere on your computer and name it something like NUVI CONTENTS. Then copy and paste or drag and drop, however you want to do it, all the contents of your NUVI. This way if you do something you didn't mean to, like delete a language, you can just put it back in.
Now what you need to look for are 3 folders, one is the HELP folder which is pretty useless once you get the hang of the Garmin unit. As a matter of fact I never even used the HELP button on the Garmin unit, because it's so easy to use.
The other folder is the VOICE folder, open it and start deleting the languages you are not likely to use or need. Make sure you DO NOT delete American English, unless you want to stick to British English. Of course I am assuming you need English, but regardless it goes for whichever language you want to keep. Assuming you are keeping American English these are the names of the files you need to keep in the VOICE folder english_american_.sum and English_American_.vpm.
The last folder is the TEXT folder, open it and delete all the files if you want. American English is the default so it won't go away, but regardless you'll have a back up anyways...RIGHT? LOL
I hope this helps you, and if you have any questions lay them on and I'll see what I can do for you. But I will say that I just bought my Nuvi back in April of this year so I am still learning a lot about it. I am working on tweaking the XML file so that it will ready more than 1 map on the SD, right now we are limited to 1 map per SD card.
Jul 19, 2008 | Garmin nuvi 200W GPS Receiver
Update 2009 maps
Connect your unit and navigate to the directory under "My Computer" where your GPS is located.  Usually called Garmin.  Open it and find the file called voices.  Delete all of them except the American one and it will give you more than enough room to load the new map.
Garmin C510 wont install download Europe maps to Unit
Take a look at the Garmin support page - there is a Question " Why do I get a not enough space message on my Nuvi2xx when trying to update my mapping?"
It tells you how to remove the unused voice files to free up space.
I have a Nuvi 255WT and deleting the voice files alone was not enough, so I set about removing a lot of other stuff *** NOTE THAT IF YOU FOLLOW WHAT I DID, DO IT AT YOUR OWN RISK **** it worked for me but there is always the risk of deleting a file that the device needs.
Also I was stupid and didn't try and save the files to a directory on my MAC before deleting them, from the satnav - worth a try so that if you can do that you have a chance of recovering one that you delete if you want it back.
First I also removed the un-needed text files - leaving only the 3 British-English files
Then I removed all of the POI files that were clearly examples/samples
Then I removed all of the Vehicle files except the one I was using
Then I removed all of the large ExtData files - now that was the one that caused me the most worry as I wasn't certain what they were there for!
This gave me a bit over 140Mbyte of free space which was enough to install the 2010 update for all of Europe.
Now I don't know whether the C510 has the same amount/less/more memory than the 255WT - so this may or may not work for you.
I didn't have an SD card available, which is why I went this far. I am going to get one and see if I can find out how to load the maps onto that.
cheers - Jeremy
Jul 05, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Garmin Nuvi 200 2009 Map Update
Here's what worked for me. Nuvi 200 brand new w/2008 trying to upgrade to 2009.
After registering and download the map 2009, I started the install. I go to a point where I was told I needed 37MB more room. I went thru windows explorer and looked in the Nuvi. I went into the language folder and moved all of the languages I didn't need to my hard drive. I then went into the HELP folder of the Nuvi and again removed the all of the languages I did not need. I then went back to the install program and hit retry. All good from there. I hope this helps.
Jul 03, 2008 | Garmin nuvi 200W GPS Receiver
Deleted voice
Hello Sallilou,
If you deleted the voice files without backing them up you can try running the Garmin WebUpdater software. This program updates the operating software for your GPS and can be used to update maps and other files. It may be possible to reinstall the voice files using WebUpdater. (To download the WebUpdater software go here.)
Some of the Garmin products do have voice files available for download via the Garmin website. (Namely the Quest product.) However the Nuvi 200W does not appear to have such files immediately available for download.
If you aren't able to update the voice files this way I would suggest you give Garmin a call directly.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 13, 2008 | Garmin nuvi 200W GPS
Garmin nuvi 200W GPS Receiver Logo
242 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
