Question about JBL Sonnet Computer Speakers
Jbl sonnet computer speakers
I think I have a dry joint on the input inside the sub woofer casing. How do I get into the casing. Taken out the screws but cannot open it up with out damage. thanks chris
  • Anonymous Jan 11, 2009
    I am having a hell of a time getting into mine.Can't seem to find any other screws, and the case doesn't pry open.
  • salmonface May 13, 2009
    hah, i broke mine trying to open it!
    anyone got any clue where i could buy another one?  or would i have to get the whole set again?
I also own MH=505 & was able to open up the sub-woofer by re=installing the 4 corner plate screws about 1/2 way ,then using a finishing claw hammer VERY lightly use the claw under the screw heads & lightly pry gradually on the screws until free.USE extreme in doing so as the amp ,circuit board is also included. Happy Motoring ,hope you fix your rallle....Regina Ca
Posted on Jan 31, 2008
The only way in is to take out the four big screws around the edges, 5 screws in the heat sync and then remove the base level knob and take off the hex nut and washer holding that on. Then presto your inside.
Posted on Jan 26, 2008
    Novelist:
  • 130 Answers
Check under the stickers, sometimes screws are hidden under rubber feet, and stickers. If there is a sticker you can rub it with your finger and feel if a hole is under it. Just look at how the rest of the screws are. If you have taken out 5 in the corners and a sticker or a rubber pad is in the last corner chances are its under that one. Also sometimes they use a rubber seal to create an air tight seal in the box. Sometimes this seal can be a little tacky and you need to pull on it a bit before it pops loose. If your sure there can be no more screws then it maybe stuck
Posted on Apr 05, 2006
How to open the subwoofer unit? There is something lose inside and I don't know how to open it. And I can't find the service manual on internet.
particular model may please be mentioned.
In general, there is two types of packaging
1. The bottom or the back or the front will have screws, you can unscrew and that's it.
2. Some sub-woofers are factory sealed, that means all their panels are glued shut. Now here's the problematic part. Usually you can't open a glued shut sub-woofer without inflicting some cosmetic damage. You may put scratches on it or vice versa.
Still if it is very essential, you may have to use some thin and flat object like a praying knife or a flat head screwdriver. Use them with caution as applying too much pressure at wrong angels may result into ricocheting into your hand / fingers.
May 14, 2014 | JBL Encounter 2.1 Computer Speakers
I have a JBL TLX CSS-SUB1 sub at the back are where you connect the speaker wires to the receiver but i don't know witch wire goes in what? i have no clue
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | JBL Audio Players & Recorders
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
Nov 01, 2010 | Audio Players & Recorders
Cannot get the sub woofer to work.
Now tell the NAD you have a subwoofer. Page 15, Figure 13, etc. and Page 18 - 19.
Mar 05, 2010 | NAD T770 Receiver
Buzzing sound coming from my jbl creature speakers no music
Try this Double click on the volume control icon in the system tray.Click on "options"--"Properties".Select Line-in and Mic.Mute them. I hope this solves your problem.
May 14, 2009 | JBL CREATURE II Computer Speakers
Jbl eon
the eon woofer is designed to fit the small frame of the inside cabinet. The EV woofers look too deep to fit but you can try. I do think that the built in amps were set to work with only the JBL woofers so there might be a signal problem using the built in amp. The eon face seems to have their own screws to hold the grill so if they aren't holding you can drop some cement to help hold the srews in place. The front does not allow removal of the woofer so it seems whatever you do should not effect anything.
Nov 02, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL Eon G2 Speaker
from our experience rebuilding woofers once the lead wires get pulled too much or start to strain you have been running too much power into the woofer and making the cone move too far in and out.You need to cut the input signal from your preamp down and cut the volume down on the speaker input on you eon. We keep seeing too many of these amped speakers blown from too much signal.
Oct 12, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
Shorted Sub-woofer
try this site first; http://logitech-en-amr.custhelp.com/cgi-... but it sounds as if something has fried in the amp - if you look inside you may well see some burning marks around some of the components. Another possilility is that the cable being pulled out pulled something inside the speaker that has damaged the cone or more likely the power supply , but the symptoms you describe suggest an amplifier issue, possibly caused by damage to the power supply system. Hope this helps :)
Mar 07, 2007 | Logitech Z-560 Computer Speakers
JBL Sonnet Computer Speakers Logo
209 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
