Question about RCA P52926 52" Rear Projection Television
Older RCA Projection screen, Blue picture!
My color is turning a blue color, looks like all pictures are at night with blue haze. Is my TV worth repairing?
  • dakhon1 Sep 10, 2008
    I have about thirty adjusters ten for each color, Box is about 12"X8"
  • razzagirl Sep 14, 2008
    My older 52" RCA projection TV also has a blue haze over it. I've tried to adjust the color convergence and the color picture controls but nothing helps. Is it a goner or can it be easily fixed?
    New Friend:
  • 74 Answers
Take the front speaker cover off, then remove the four screws on the cover behind it. you will see a 2"x2" black thing with 6 controls on it 3 on top three on bottom, your looking for "screen". they should also be marked r g and b, try turning the blue down (counterclockwise). it may help a little and prolong the life of your tv
Posted on Sep 10, 2008
RCA mm32110 picture turn to blue and white like you have blue sunglasses on.
I'm not familiar with this set but it sounds like your blue crt has shorted out and is putting out so much color that it overwhelms the other colors. Is the picture also washed out? If so then your blue crt is bad. Probably not worth fixing. Let me know more about what the picture looks like.
Jan 31, 2010 | RCA Televison & Video
Our 1991 RCA P52150CP rear projection TV has gradually been getting bright cloudy blue, slight haze around letters & shapes-(especially blue channel change headings) when first turned on and then it...
First check whether all the cables from your dishnetwork are fine and connected firmly.If yes then you'll need to pull off the front of the tv, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. so we are doing real small adjustments. Turn the color off on the tv and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittant blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue crt board, or a problem in the RGB coming from the video jungle IC. A set this age, most likely will run you about 300 to 500 bucks to have this problem fixed, unless it is the picture tube.
Please do accept this solution and revert for further assistance.
Jul 03, 2009 | RCA P52926 52" Rear Projection Television
Rca D52W20 blue screen when turned on
Almost certainly the blue picture tube is bad. This is a huge job to replace and quite expensive. Generally it is not worth doing.
Mar 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Sounds like a bad blue CRT (picture tube) ITs expensive and difficult to replace. CAll a Sony service center for an estimate. but expect to spend $500-700 to replace it.
Feb 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Yellow Haze Center Screen
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Philips 43P8341/37 blue color problems
Change the coolant in the blue CRT and your picture will be new looking again. Let me know if you need more information.
Mar 15, 2008 | Philips 43P8341 43" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
101 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
