Question about Yamata FP202L Cordless Iron with Auto Shut-off
My yamata fp202L
My familypress steamer doesnt get hot turns on lets me pick a fabric but no longer gets hot
  • Anonymous Nov 14, 2008
    I have the same problem for 4months now but I still used it. if you bang on the front panel it will start heating up. each time you hit hard put an ear near the front, if you hear the humming then its working (again)
    Problem Solver:
  • 14 Answers
Most likely it is the fuse that regulates the heating element on your press that has burned out.
All you have to do is open the top, remove the heating plate. The fuse will be on the left, button shaped.
Replace the fuse and put everything back together and the unit should work.
You can buy a fuse from the company you bought your press at or contact the manufacturer.
Posted on Nov 11, 2008
I have the same problem but I still continue to use the steam press. You need to hit the front panel pretty hard and then listen closely. if you hear the humming then its working
Posted on Nov 14, 2008
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
My clothes steamer won't keep putting out steam stops after about 5 min
It sounds like it is shutting off on high temperature because of a line/scale obstruction. You may need to descale it. Use CLR (available from home improvement stores or supermarkets) or something similar. That should get it back in operation.
Jun 26, 2011 | Yamata PSS-2001 Iron
Conair GS33 fabric steamer spews too much water..can't be normal, eh?
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
Feb 03, 2010 | Conair Irons
The steam on my FP-202L stop working. I believe it may be caluicm buildup, even though I use distill water. How do I clean the caluicm out?
I've heard that Vinegar is the best for water applicances, like steamers, coffee makers, Irons, etc.
Try rinsing it out with vinegar.
Jul 28, 2009 | Yamata FP202L Cordless Iron with Auto...
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Yamata psp-990
I have a schematic that I drew of the Yamata PSP-990A and a partial parts list. Please let me know if you would like a copy. I will send both as an e-mail attachment (BMP. format).
Sep 13, 2007 | Yamata PSP-990A Iron
Yamata FP202L Cordless Iron with Auto Shut-off Logo
273 people viewed this question
Top Yamata Irons Experts
Are you a Yamata Iron Expert? Answer questions, earn points and help others
