Question about RCA 27F530T 27" TV
Screen colour missing
My RCA TV missing red colour in it, it was allright for few seconds when the tv is turned on, but afterwards the red color is gone. What problem could this be?
  • john27pa Jul 03, 2008
    My picture has no color. Its in b&w. The menu is in color, but everything else is not. I have a 27v514t that I am wondering if I could use parts from that one to fix my 27v530t. Also- the 514t was said to have no sound. I want to fix the 530t, but not sure if it has a seperate color graphics card that I can switch with from the 514t tv. I am at john27pa@yahoo.com
    President:
  • 3,130 Answers
This problem could be a few things. first if you know how touse a volt metter go to the crt pcb on the end of the picture tube. Try to measer the voltage on the collector of the red drive transistor. If when the red color goes away and the voltage shoots way up past 150 or so volts then the red drive is disapearing from the video jungle ic or through one of the componets from it. If the voltage drops way low like less then 65 to 75 volts or less then theres a cold solder connection between the b+ feed resistor that suppys the b+ to the drive transistor the driver power supply sourse.. In an extremely rare case would the Picture tube be at fault but certainly could be. Good Luck OOps almost forgot it could als be a bad connection on the crt socket as well..
Posted on Apr 05, 2006
RCA model #f27648 reds missing from picture
It sounds to be a video output stage circuit fault. Check all the solder terminals at its CRT base card, including the solder terminals of the CRT base to the card. Re-solder all the suspected solder terminals by applying a little more fresh solder. Contact any service technician. Check the solder terminals of Red color output transisotor. If needy, replace it with a new one with same number printed on it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
The fault is 'one colour predominant/absent screen'
Mar 26, 2014 | RCA F27648 27" TV
Red colour picture on plasma TV
It might need the color to reclibrated, if that does not work, a gamma electronic board need to be replaced
Jan 06, 2010 | Samsung PS42C91HDX 42 in. Plasma TV
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Colours missing from tv
There are three color guns in a TV that make up the picture. Red, Green & Blue. It sounds like you have lost the green color gun.
You can get it rpeaired again, but your TV sounds like it is ready for TV heaven.
Jul 25, 2009 | RCA 20F512T 20" TV
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
No Picture on screen
THIS PROBLEM HAS HAPPEN TO ME WHEN MY LAMP WAS
ABOUT TO DIE. WHAT I DID WAS UNPLUG THE TV SET FOR
A SHORT WHILE, THEN WHEN PLUGGED AGAIN IT CAME ON BUT THE PICTURE WAS DIM AND THE LAMP ONLY
LAST FOR FEW DAYS AFTERWARDS.
W.J.M.
Jun 23, 2008 | Hitachi 50VS810 50" Rear Projection HDTV
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
RCA CTC203 no red colour
Did you change the resistor by yourself? I am not sure if your TV has manual adjust on the back of the TV that you can adjust. Some times turning the TV Off and unplug it from the wall helps because it resets the TV. Check your Back ground color and see what is the dominating color. Blue, Green or Red. If this doesn't work please call a professional to look at it.
Jun 18, 2007 | RCA F27649 27" TV
Red screen!
your tv needs to be repaired.the color circuit.CRT or neck board could be defected.good luck.
May 18, 2007 | RCA F27615 27" TV
RCA 27F530T 27" TV Logo
97 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
