My printer will not print after sitting for about 30 minutes. As soon as I turn it off and then back on the job I previously sent, prints out. I tried changing the amount of time before it goes to sleep but this does not correct it and does not seem to be related. You can hit the check mark to wake it up but it still will not print until turned off and then on. Source: How do you turn off the sleep mode in a HP 3600 printer?
This is the only solution is see and it didn't solve the problem
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
