Question about Microsoft Xbox 360 Console
I have sound bt no picture on my 360
Hey i have sound but no picture on my xbox 360 console. I have tried getting a new AV cable but it still has the same problem. I have also tried the cocnsole plugged into another television but alas no :(. I know a lot of people say the wet towel trick but i dont want to try it as im nt sure about the idea of putting a wet towel on an electrical item. please help me out and give me some idea of wat to do :)
    Scholar:
  • 45 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazingdevice also has some more common problems like Audio but no videoproblem, disc read error etc. Microsoft is providing extended warrantyonly for red ring problem. Means you will have to spend some money toget this problem repaired also if you plan to send your xbox toMicrosoft, you will have to wait for 3-4 weeks to get back yourfavourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
Posted on Feb 21, 2009
My xbox 360 won't sow the picture but i have sound
try it in another tv with av cable
if u are using hdmi cable try changing the existing cable
if it works in another tv , go changing the setting in the displaysettings and video settiing
Mar 05, 2010 | Microsoft Xbox 360 Console
There is sound but no picture
it could quite possibly be the av cables, try a different tv or see if you can try someone elses cables before purchasing new cables
Oct 31, 2009 | Microsoft Xbox 360 Console
Xbox 360 with no picture
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
The main reason why its acting that way its possible that the AV PORT is faulty or its your cables..
Apr 07, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Sound but no picture
On some av cables for the Xbox 360 there is a switch on the cable itself where it plugs into the Xbox that must be in the correct position. I hope this helps you.
Nov 15, 2008 | Microsoft Xbox 360 Console
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
No picture...
I would try some of these troubleshooting steps;
  1. Make sure that the AV cables are 100% secure.
  2. Try an new AV cable.
  3. Try your console on a different TV.
  4. Call xbox customer support at 18004MYXBOX
May 31, 2008 | Microsoft Xbox 360 Console
Sound works but no image
This means the AV cable is not detected, try one of these...
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
If this is helpful at all, please rate, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
