Sherwood RX-4103 2 Channels Receiver
Problem for Sherwood RX-4103 2 Channels Receiver
Left channel out
By waxmbordz on Apr 05, 2006
I have a sherwood 4103 receiver and my left channel is out. Not a speaker issue, or input issue as headphones, and cd, aux or tuner outputs all have the dropped channel.
Is this a problem I can fix myself?
thanks...Dave
Same Problem
Sep 08, 2008
-   Same Problem... -   Guest
Dec 16, 2007
-   the output for the left speaker of both the speaker sets (A and B) is out-   butingting
Dec 08, 2007
-   left channel does not work-   Guest
Solution #1
posted on Apr 05, 2006
Somewhat Helpful)
techman
Rank: Guru
Rating: 86%, 7677 votes
probably I would say no. Unless you know how to read a schematic or know how to do certain small static checks on the output devices and the drivers as well as the power suppy feeding these devices.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
BowerR64
Rank: Wiz
Rating: 80%, 985 votes
Does it have any mechanical pots? balance pots? check all the mechanical stuff first maybe the balance pot has a bad connection or somthing. Any slider controls? check them also
Was this helpful?
Yes
No
Solution #3
posted on Jan 23, 2008
Somewhat Helpful)
Zpike
Rank: Apprentice
Rating: 75%, 1 votes
There are NO mechanical pots on the system. The "pots" for volume are a special bitsequence comparator, and the signal for the gain on the amp is a modulated matrix signal.
The most common problem for this kind of amps are the safety-thermal switch... They are normally located really close to the output for the speakers. Normally gray or black boxes (30x10x40mm). Flick your finger on them with volume at 9 o'clock...
If you can hear a click, and the sound appear again you've found the sollution.
NOTE! Hazardous currents are present inside the cabinet, mind your fingers, arms and other bodyparts.
Was this helpful?
Yes
No
Popular Solutions for Sherwood RX-4103 2 Channels
Questions and Unsolved Problems for Sherwood RX-4103 2 Channels
Do you recommend Sherwood RX-4103 2 Channels Receiver?
Answer
Answer
How do I finetune the tuner, I can get 106.00 but not 106.5
Answer
What is the code for 4103 to work with a comcast remote
Answer
I have a Sherwood RX-4103. Can't find the remote code that works with Cox remote.
Answer
ive replaced resister #R384L with 220 ohm. 1/8 watt now ive blowen the cap. #C382L replaced that... (More)
Answer
where can I download a manual for the RX-4103 receiver?
Describe your Receivers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Receiver Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
