Question about Creda Europa E010E Electric Single Oven
SQUEAKING FAN IN CREDA OVEN
HOW DO i STOP THE FAN SQUEAKING, IT HAS BEEN SUGGESTED I SPRAY WITH WD 40. I TRIED THIS BUT NOTICED THAT IT IS FLAMMABLE. IT MADE THE OVEN SMELL SO I HAVE STOPPED USING IT. WHAT ELSE CAN I DO (IT STILL SQUEAKS) IS IT THE BEARINGS?
  • zgygreen Sep 11, 2008
    The wd40 now appears to be successful, for the time being anyway, I too think it might be the bearings, in which case I will probably just change the oven, thanks for your help.
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
This should help
Posted on May 27, 2010
    President:
  • 1,462 Answers
It is usually the bearings and wd40 not a good idea. i always found that with a noisy fan the only cure was to replace it
Posted on Sep 10, 2008
Creda concept c361e main fan oven not working have installed new element
Also check the thermostat as these can fail and stop the oven working. If that is OK, then check the operating switch.
Feb 29, 2016 | Creda Ovens
How to Stop oven door from squeaking
Try spraying some Pam non-stick spray on the hinges and moving parts.
Sep 10, 2014 | Thermador Ovens
Creda fan oven not heating grill is working and light is on in oven
If the fan is working o/k, then the oven elemment has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
If the fan is not working, then it it could be the timer is on auto, and not on the manual setting. Check your user instructions.
Feb 02, 2011 | Creda Ovens
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
Main fan oven in Creda C130E won't heat. Everything else working ok. Suspect the element. Does oven have to be removed from its housing to replace the element?
If you remove the inner rear panl of oven compartment, you will see the element.
If you can see removeable screws, then you can change the element from inside without the need to remove from housing.
If screws cannot be removed from inside, then you will have to remove the oven from housing.
Please leave feedback for my suggested solution.
Thankyou.
Feb 16, 2010 | Creda Ovens
End of the self cleaning cycle, lower oven door stays locked
the heat seems to have seized the lock. if you can tap at it with a screwdriver and hammer, the vibration may knock it loose. you can also spray it with liquid wrench or wd-40 first
Jun 21, 2009 | Electrolux ICON Designer E30SO75ESS Oven
Creda Europa E010E Electric Single Oven Logo
832 people viewed this question
Top Creda Ovens Experts
ashburton
William Robinson
William Robinson
Dan Webster
Dan Webster
Are you a Creda Oven Expert? Answer questions, earn points and help others
