Question about Amana AER5515QA Electric Kitchen Range
Oven and clock inop
On the display there is one red dot that is all. the clock and oven is inop. thank you for your help in advance.Roy Clark rclark1960@msn.com
  • 2 more comments
  • Anonymous Nov 11, 2007
    how
  • poshgal Jun 11, 2008
    oven wont come on there is a red light on thats saying auto help
  • accord845 Aug 04, 2008
    clock operates, however, I'm unable to change the display time. Oven will not come on at all.
  • Anonymous Apr 06, 2009
    after running the self-cleaning cycle, my maytag oven display says 'lock' and the oven will not operate.
  • 30 Answers
You might have a problem with the circuit breaker - reset it by pressing the switch ocated on he lower edge of the backguard (in Canadian models). There are several things that could cause the oven not to operate, but generally you would get a message on the display - "Lock", "Sabbath" etc. Just in case your display is damaged and that's why you don't see any message, try to press and hold the "cancel" and "cook and hold" pads for three seconds (to unlock the oven in case it is locked), and then check to see if the oven works. if not, repeat this procedure (to make sure that you didn't lock it just now), and then press and hold the "clock" pad for three seconds (to unlock the oven in case it is in "sabbath mode"). If it still doesn't work, you might need to replace a fuse.
Posted on Apr 05, 2006
Yeah, thank you. Holding down the clock button for what seemed like 5+ seconds worked....thanks.
Posted on Aug 31, 2009
A Maytag Gemini "Sabbath " display Originally I thought it said 5Ab bACH" Hold the clock switch for 5 - 10 seconds -
Posted on Jul 29, 2007
  • Shawnw2114 Dec 30, 2010
    I had the code "5Ab" on my Amana stove. I held the " clock" buttob for 5 seconds and it fixed the problem!!
When trying to set the oven timer the timer would not change or start after setting a time. By pressing the "Cancel" and "Cook and Hold" it locked the display and then by repeating the above it cleared the timer issue.
Posted on Jul 08, 2007
Candy fl 134 x uk , single oven ..... oven works fine ... clock/ timer is dead and keeps making clicking noise , when not in use i power it off ... do i just need to replace the clock ???? Thanks roy
[n 75 years I have never heard of anyone powering off an oven when not in use . those little clocks do not use enough electric to worry about waste
Feb 25, 2017 | Candy Ovens
Is roy clark dead?
Why is this posted to the sewing machine category?
Jan 16, 2017 | Singer Sewing Machines
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Thermador 30" Dual-Fuel Range 0FF error
I am quoting above because I really need help. "When I push any of the function buttons on the oven console (Timer, Bake, Broil, Clock) the display shows 0FF in red next to the clock. The oven will not turn on and the timer will not work. I can not find any troubleshooting information on this problem. The oven is a model RDDS30V. Any help would be greatly appreciated!"
Apr 17, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
Clock and oven inoperative on elan rangemaster 90
Your electronic oven control (clock) has failed. This being a new appliance, it will be covered under warranty. Call the dealer and ask for the manufacturers warranty/customer service phone number or ask if the dealer provides warranty service. You will need to provide them with the Model and Serial number to obtain service, so have this ready when you call. After service is complete, please connect your oven to a quality surge suppression/arrestor device. We recommend these... http://catalog.belkin.com/IWCatProductPage.process?Product_Id=124911 , they can be found here... http://www.belkin.com/wheretobuy/show.aspx?pid=&targ=19&ttr=3e86a31d-23dd-4b8d-acbf-2adf1ce9ecc0&cid=1
Aug 11, 2007 | Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
Oven display and oven are not working AT ALL
Most electric range ovens are controlled by the electronic oven control (EOC). If your oven is not working and there is no display on the clock, more than likely you have a bad EOC. The board is not serviceable and has to be replaced. I hope this helps.
Jul 24, 2007 | Whirlpool RF3020 Electric Kitchen Range
No display - oven/timer/clock inop.
Most likely control / clock has gone bad and needs replacing
Nov 11, 2017 | Frigidaire GLEF396 Electric Kitchen Range
No display
There is a safety thermostat located in the back side of this oven. When looking at the oven, from the back side, it will be located on the right side. I have a part number of 318003613. Good luck.
May 27, 2006 | Frigidaire FEB30S5DC Electric Single Oven
Amana AER5515QA Electric Kitchen Range Logo
1,041 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Paul Carew
Archie Ferrarini
Archie Ferrarini
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
