Question about Dishwashers
My dishwasher was seldom used and eventually became completely inoperative
    Genius:
  • 2,035 Answers
First check if there is power in the unit if not then are changes of fuse blown out , if not get it serviced by authorized service personal , regular usage of the will avoid these problems...You can use this link :
http://www.repairclinic.com/0047_9.asp
Good luck...
Posted on Sep 10, 2008
  • 796 Answers
Common trouble makers:
- blown house fuse/breaker
- burnt main power wire
- bad door switch(s)
- blown thermal fuse
Is there an internal fuse that needs to be replaced?
Only is it is bad, it is in the consol.
http://www.repairclinic.com/dbimages/00000077/00021847.jpg Thermal fusekit with harness(http://www.repairclinic.com/referral.asp?R=153&N=679723)
    Genius:
  • 1,847 Answers
What is the exact issue that you are facing. Kindly describe the issue in detail.
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: dishwasher
I did post to this already. If you didn't see it,.... Most likely the seal dried out and is sticking. Pour a quart or so of hot (not boiling) water in and let it set for a few minutes. Then restart dishwasher. If motor still just hums, see if you can access the motor shaft to manually turn it to break the seal free. If you get it going this way (most likely will) just remember to run the dishwasher for a quick rinse every week or two even if you don't have a load to run through it. That will keep the seal lubricated. If you will be away for an extended period of time (several months), try to add a couple cups or RV antifreeze in the tub. If this helps, please list it as a "Fix Ya", thanks.
Frigidaire dishwasher won't dry dishes. Less than two years old. Seldom used. FDB1100RHM. Could this be the heating element? Could this be something we could fix?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2011 | Frigidaire Dishwashers
Our glasses and dishes have a film on them, which I can only remove by using a calcium-lime remover product on them. The inside of the dishwasher is also coated with a film residue as well. I started to...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 06, 2011 | Frigidaire PLD4460REC Stainless Steel...
How do you adjust latch on trunk. Motor became inoperative and I had to disconnect. Lid will latch but not close completely.
hello we were disconnected fuse number 8 blue 15 amp is the pull down motor # 14 yellow is the trunk release 20 amp Regards, Lee
Oct 03, 2010 | 1997 Lincoln Town Car
After my dishwasher fills with water, and starts to clean it doesn`t do anything but humm.
more than likely something is sticking in pump, remove access panel and reach into motor opening and try to turn motor over by hand if you can (using motor cooling fan blades) .This problem happens more often if machine is used seldom
Sep 30, 2010 | Amana 24 in. DWA22A Built-in Dishwasher
Fisher and Paykel dishwasher noisy fan
Have you got your dishwasher on an extended drying cycle?
Normally it works for about 10 minutes after the wash cycle is complete - not hours.
Jan 21, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Our Bosch Dishwasher Not Draining After Normal Washing Cycle
make sure the filter is not blocked by anything like a straw or just junk
Apr 02, 2009 | Bosch Dishwashers
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
DISHWASHER WAS SEJ\LDOM USED AND EVENTUALLY BECAME COMPLETELY INOPERATIVE
Hi bnedict,
I'm Harvey the Master Plumber.
Your statement didn't include a question so we'll assum you want to know if you should repair it.
If it has a few years on it, it's my opinion that repairing it is like throwing good money after bad. I would seriously recomend replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Dishwashers
Dishwasher
I was using my dishwasher very little and eventually it became inoperative
Most likely the water evaporated and the pump seal dried out, causing it to stick. Try pouring a quart or so of hot (not boiling) water into it, letting it set for a few minutes, then starting it. If the motor still just hums, with some brands you can access the motor shaft or cooling fins under the motor and break the seal free by turning the motor shaft by hand.
Dishwashers Logo
125 people viewed this question
Top Dishwashers Experts
