Question about Samsung Digimax L830 Digital Camera
Memory card locked
Can't unlock my memory card to take a picture
  • 7 more comments
  • kochekow Dec 05, 2008
    bought sd extreme 3 4gb...cant unlock it with the tab on the side
  • Anonymous Dec 25, 2008
    negative
    memory card locked
  • skipman Feb 14, 2009
    saying card locked
  • ppetal13 Feb 23, 2009
    when i take pictures and if their ugly and i try to deleat them the camera says card locked
  • vanikamps_07 Mar 03, 2009
    I have a samsung L73 and my memory card is locked and I'm unable to take pictures...how do I unlock my card?
  • Anonymous May 07, 2009
    Casio EX-Z89 camera. When I turn it on it says "The card is locked." I bought a new memory card thinking the old one was spent. New memory card - same message. Any ideas? thanks.
  • albebaran1 May 08, 2009
    i cant take pictures because suddenly my camera shows a sign: card locked. I dont know how this happened, how can I unlock the camera?
    Reyna Diaz.
  • zyonziairr May 11, 2010
    IT SURE DID IT WORK AS SOON AS I PULLED THE TAB OVER I CAN TAKE PICTURES IT WORKED LIKE A CHARM THANKS!!!!
    Scholar:
  • 48 Answers
Sounds like the 'lock' tab on the memory card has been moved to the 'safety' to prevent you from re-writing your card accidentally
Fix it by:
1 remove memory card from camera
2 look for the very little tab/switch on the front of the card
3 slide it to the unlocked position (opposite of now)
4 put it back into camera...should now allow you to take pictures
if the tab/switch is missing do not dispair...
-use a small piece of clear tape to cover this 'tab/switch' opening
-this is the same concept as cassette/vhs/ 5 1/4" floppies...removing the 'tab' to lock it
Posted on Oct 08, 2008
I had the same problem with my memory card in my Canon SD1100 Elph. Tried the fix that bearb suggested and it worked! Thanks so much!!
Posted on Jan 14, 2009
ON THE VERY THIN EDGE OF THE MEMORY CARD THERE;S A VERY VERY SMALL DIFFERENT COLOURED SWITCH SLIDE THIS OVER & PRONTO IT WORKS (MINE WAS A SAMSUNG D75)
Posted on Feb 03, 2009
The sd card works just like the floppy disk, i was so confused when i saw everyone talking of the camera it bishop123 mentioned the card and my memory clicked back. thanks alot bishop123.
Posted on Nov 19, 2009
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
MEMORY CARD LOCKED
All SD cards I have ever seen can be locked with a little slide on the left side as you face the label. if the slide is up, the card is unlocked and can be used for taking pictures. If the slide is down, it is in the locked position, which prevents it from overwriting anything that is currently on the card. Before you unlock it you may want to verify that all pictures on the card (if any) have been saved because once you start using the card and overwriting its contents, the pictures are gone forever. If the card is empty, just unlock it, format it and start taking pictures.
Dec 22, 2013 | Nikon D3000 Digital Camera
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
When i turn on my DSC-W310 camera it says memory card is locked. So I cannot take pictures or find a way to unlock the memory card. what i do?pls explain with pictures
If the memory card is a SD memory card then
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Feb 22, 2013 | Sony Cybershot DSCW310 Digital Camera
My memory card is locked am not given lock number how to remove lock 2gb micro
Look closely at the memory card itself. There should be a tiny picture of a lock indicator on the card and a little tab to click or move to the lock position. There should also be a picture of an unlocked lock to signify which direction you need to move that little tab in order to unlock the memory card. Try sliding it to the unlock position to solve your issue.
Sep 12, 2011 | SanDisk 2GB microSD Memory Card
My my son removed my memory card from my computer without first asking for it to be removed. All my pictures are now on the card and I can't open it. How do I unlock the card?
Welcome to FixYa
Whats Showing when Trying to Open Pictures in Card.You can Open it by Putting card again to PC to view pictures.
If card is Damaged then you cant see it any more...
If card is LOCKED-It need to be Unlocked with Unlock device-then All data will be deleted..
I dont think it is locked....ONLY by just Removing from PC -card will not be Locked...
You can Open it manually...Let me know if you need further assistance...
Thanks for Connecting FixYa..
Aug 31, 2010 | PNY 2GB microSD Memory Card
The card, or memory chip in camera is locked, and i dont know how to unlock it, so now i cant take pictures, or upload my pictures, or even delete photos,i just need to know how to unlock my camera.
This used to happen when the write protect lock on in the memory card. Refer the manual to see how to remove the memory card.
After removing the memory card, unlock the write protect tab as shown in the fig. d7656e6.jpg
Apr 20, 2010 | HP Photosmart M547 Digital Camera
My camera says card locked
Your memory card has a lock switch, move the switch to unlock.
Jul 02, 2009 | HP Photosmart M447 Digital Camera
My memory card locked! i need to know how to unlock it
There is a small switch at the base that needs to be moved to the "Unlocked" position. It's at the side of the card.
Mar 26, 2009 | Cameras
Memory card loeck
Have you tired to unlock memory card unlock button ? SD cards do have write protection physical lock. take a look at this pic and unlock it, good luck!028cf96.jpg
Dec 15, 2007 | Canon PowerShot A75 Digital Camera
Samsung Digimax L830 Digital Camera Logo
878 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
