Question about Ducane Affinity 3100
Can i run gas bottle inside the unit
Hi.. bought a sale 3100 and no instructions is it safe to run the gas bottle forom inside the unit whilst cooking?
    Problem Solver:
  • 18 Answers
Yes, it was designed for use that way, assuming there are no leaks, check with soapy water.
Posted on Sep 10, 2008
Get out of safe mode
Hi!
If you're starting up your computer, press F8 before the Windows logo appears and select "Start Windows Normally".
If you need to exit it whilst inside of Safe Mode (booted into Windows), follow the instructions below:
How to Exit Safe Mode
Hope this helps!
Mar 01, 2015 | Computers & Internet
Welli just bought an avent bottle warmer online and instructions didnt come so i turned it on an put it on bottle and the amount of oz and it dint warn any so could u tell me how to use it or how it works?
turn on,select where bottle came from,room temp/fridge/freezer by pressing power button.
Press size button to amount of water/milk in bottle,when at right level hold button in,unit will bleep
May 21, 2010 | Toys
Whirlpool gold GT4175SPS-2 inside door paint is flaking and revealing metal. Is it safe to use?
Scratches, flaking and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord first.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
May 09, 2010 | Microwave Ovens
Is there any difference in bottle gas heater and natural gas heater
by bottle i am assuming you mean propane. yes there is a difference , natural gas is mostly methane gas (ch4) a very small molecule, propane is (c3h8) a much larger molecule. so they require different gas nozzles and cannot run a unit on the other fuel, some can be converted to run other gas. generally natural gas units are cheaper to run, but cost more for installation as a gas line has to be run to the unit and benefit of not running out of fuel. hope this helps.
Apr 23, 2010 | Pentair Minimax Ch 250,000 Btu Natural Gas...
What kind of oil does the yardman 3100 use? and does it use standard gas like in a lawn mower? what is the mix ratio?
This unit should use 3.2 oz 2 cycle oil per gallon of gas. You should be able to buy this at any hardware/lawn and garden store. It will say 2 cycle oil. It is OK to use a synthetic as well as petroleum based. It's handly that it comes in the right size bottle to mix with a gallon of gas. You use regular gas that you would purchase for a mower or your car. Take your gas container, put a bit of gas in at the pump, add your oil (the 3.2 oz bottle) and put the rest of a gallon in the can. This filling procedure will mix your oil with the gas just fine.
You may be able to get more info from the website that has your owners manual.
http://dl.owneriq.net/5/578f1a77-3a03-c804-0d71-a5ad3a66f4b4.pdf
Nov 28, 2009 | Yard Man Mulchinator QuickShift BlowerVac...
I have a 96 grand prix se 96 3100 Sfi V6 when i start the car it dies on rare occansions and id like to know why / and if it is safe to put fuel injector cleaner in my car to see if it helps the issue
The cleaner will not hurt anything. Your motor will just burn it up like fuel. I use the STP (red bottle) because it says on the bottle that it gets rid of condensation in the fuel tank. Condensation (water) does form and collects in the bottom of the gas tank. I use the fuel treatment 3 or 4 times a year and I think it really works. I have a 2001 Monte Carlo that I bought new and it has 177000 miles and it gets 34.5 mpg highway.I have been useing the fuel treatment from the beginning. It has the 3400 V-6.Its basically the same engine you have.
Also you must install a new fuel filter every 30000 miles. The tanks at the gas stations are filthy.
Also check the condition of your air filter and replace at 20000 max.
Transmission filter and oil at each 50-60000 miles.
I hope this info helps you.
Sep 24, 2009 | 1997 Pontiac Grand Prix
I have ir 3100 N the error is E 013 please if i
You should empty the waste toner bottle ( open the front door, the bottle is in the middle of the copier, you have to unscrew the small piece of plastic on top of it, remove it, remove the 2 small plastic pieces on each side of the top of the bottle, clean it, empty the bottle, clean it, put the 2 plastic pieces on it, put the bottle back inside the copier, ON / OFF the copier and it ll works :)
Reagrds, Mug71
Sep 14, 2009 | Canon Office Equipment & Supplies
Stuck on wrong current location
hi,
No need to worry about that this problem arise when the unit is not piciking up the signal.In that situation what you can do is ,you can do a small reset to your unit . In the left hand side bottom corner you can see a small pin hole named as reset
.What you have to do is turn on the unit and insert a paper clip in the reset hole and gently push it inside.So the unit will be reseted surely 100% it will show your location.....
Feb 07, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Ducane Affinity 3100 Logo
82 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
