everq... indicated that his solution for WD62327 TV Problem is valid for all Standard Televisions
My son touched my television screen with a magnet in two spots leaving two discolored areas on the screen,purple and green in hue. I read many quick solutions to this problem on the net and none seemed to work completely,so what i did is took the same magnet that touched the screen and held it in my fist,then with TV on i waved my fist all around the screen working from the spots outward to the edges and this worked completely! Hope this helps someone..
unplug the set overnight and turn on cold.. if the degussing is working it will fix the problem but if it took away some of the discolor on the screen but not all of it then try this step a few times.. After a few days a degussing coil will be needed to clear up any color spots.
Comments:
May 25, 2006
- Wait a second pal where the heck did you hear that from ??? what a joke!!!!!!!! n replace a crt??? are you kidding?? I must have cleaned up a thousand or two at least . where did you get your info from KMart???? you must be a sony distributor???lol always wanting peeps to replace parts that are generic types with original sony parts?? yes some do have to be original but not all as those japs say!!!!!!!!!!! what a jole!!! replase the crt for a magnet spot
take indicated that his solution for KV-32S26 32" TV Problem is valid for all Sanyo Standard...
Hey waths happen...? the degausing coil is not working and thaths all check de degusing sistem if you are a tech prep.. or refer to a cualifi tech... contac me ill teach you ....
have tried 2 coaxial cables but do not get a sharp picture. Could it be an internal cable pin TV...
(More)
have tried 2 coaxial cables but do not get a sharp picture. Could it be an internal cable pin TV issue? This happened many years ago with a TV I gave up only to find out the problem was with the end of the cable coming into the house & connected to the TV. This time that cable as well as the cable connecting the setup box to the TV worked fine on the TV that the Sanyo 27" replaced. I tried another cable ( that works fine on my 13" Sanyo) but get the same not sharp picture. Naturally, I have tried adjusting the picture.
Hello. I have a universal remote for my Sanyo DS27800 although I am running into a problem not...
(More)
Hello. I have a universal remote for my Sanyo DS27800 although I am running into a problem not having the original remote because on the menu screen on the tv, the button will not take me down to channel search which is what I need to do for cable. I have no cable box, just the cord plugging into the back. What can I do?
