Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I need help!
How do you remove the drip pan from a whirlpool gold sid by side? power outage due to hurricane left us without electricity for over a week. we have cleared out the fridge, but the smell remains. it seems that the only thing left to clean is the drip pan but we can not get to it.
  • swtato Sep 28, 2008
    THat is not the issue, I have the same problem.  I too lost power due to Hurricane Ike.  It appears some of the items that defrost and melt run through to the overflow pan below the fridge.  I could not figure why the disgusting oder was so strong in the kitchen after cleaning the fridge.  I got down and noticed the smell was strong when the fan would blow and then noticed a slimey brown liquid in the bottom of the plastic overflow pan.  I removed the cardboard cover off the back of the fridge and there was no way to remove it due to bracing and copper tubing.  If you look at the front you might be able to remove the water filtration to slide it out from the front, but that is the only way I can see?  I hope someone has an easier solution.
    I have been using a 50/50 bleach water solution to kill and disinfect the pan.  it is working and takes about 2 days to evaporate the water in the pan, but I would really like to remove the pan and clean it so I do not have the bleach smell in the house.
    Any advice?
    Problem Solver:
  • 7 Answers
I had a problem similar to this as well, ungodly stench coming from under the fridge. I figured "must be the drip pan, easy to fix" totally wrong. I spend the better part of about 10 minutes trying to decide weather or not applying force to remove the from grill would break the damn thing or if it would actually come loose. After tugging like a maniac it did finally come loose. then i looked at the drip pan. It was taped down to the metal under cage. Cut the tape and Viola, came right now....NOT... I spend almost a full hour toying with this pan and the water filter and everything else and here is what i found.
To remove the pan you first need to unbolt the water filter holder and move the metal wire connecting it to the frame off to the side. (be very careful you do not pull the hoses out of the filter or apply too much pressure pulling and pull the hoses loose elsewhere) you then must unbolt the wheel that is in that same area as drip pan and water filter. Remove the wheel completely, (i stuck some magazines under the corner where the wheel was to come out of and it rested right on them.) now push the metal bracket holding the pan in place down until it no longer creates an obstacle and then bend the pan slightly as you pull it out. Don't bend the pan too much or it may crack but it actually slides out when pulled if "creased" in the center. It is a real ***** and there may be an easier way to handle this but this is my solution and the nasty pan in now nice and clean.
As far as spraying bleach in there goes i advise against it, the first thing i noticed when i got the pan out was that is said in big letters "CLEAN WITH WARM WATER ONLY." I though this may be more appropriate as a sticker in a place you can read it rather than on the pan you may not be able to get out :)
Posted on Oct 01, 2008
The drip pan is not meant to come out.... its L shaped.... use a turkey baster and a chamy to load with bleach and water or vinegar and water and drain out repeatedly using the chamy to collect water. I got lots of mildewed lint out.... and i didnt break my back trying to get the pan out. dont forget to pour the water down the drain line in the back of the freezer and refrigerator.. to get the lines cleansed.
Posted on Jan 26, 2009
  • 750 Answers
Hi amfreerksen,You asked,How do you remove the drip pan from a whirlpool gold side by side?
Most refrigerators today are frost free and therefore have no drip pan to dump!
The condensation is blown over the hot compressor and it is evaporated!
This is how frost free works.
Did you get flooded and the flood water got into the mechanical area below and now it's siting there and stinks? In a day or so it will evaporate away like the condensation.
I think that people in a flood do use 2/3 water and 1/3 bleach in a spray bottle to disinfect, right?
The fridge should be on roll able wheels where you can roll it out and disinfect the floor under it!
In the back on the bottom is black card board screwed in to the back to access the compressor!
If the fridge is back to the correct temperature now it can keep your food cold when you turn of the fridge for 2 hours.
UNPLUG THE FRIDGE FIRST AND IF THE PLUG IS NOT REACH ABLE,THROW THE BREAKERS OF FIRST, DO NOT TOUCH ANY THING WITH YOUR HANDS OR ANY THING
SO then if you want you can lightly spray this solution on the bottom of any pan or what ever you find that has the smelly water in the bottom of the compartment!
If you do not open it!
AFTERWARD LEAVE THE FRIDGE OFF TILL THE SOLUTION EVAPORATES!
it will still be cold for 2 hours!
BUT UNPLUG THE FRIDGE FIRST AND IF THE PLUG IS NOT REACH ABLE,THROW THE BREAKERS OF FIRST, DO NOT TOUCH ANY THING WITH YOUR HANDS OR ANY THING.
I do not know how old the fridge is???
But I saw an interesting report.
Thanks for giving me the opportunity to help!
Let Me Know how you succeed!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Posted on Sep 21, 2008
Drip pan replasment on mzsd2665heq
Hello there,
To remove and replace the drip pan on your refrigerator, please follow the instruction below:
  1. Unplug the electrical cord of the Maytag refrigerator from the power outlet before attempting to remove the drip pan.
  2. Detach the grille on the bottom of the refrigerator in the front, pulling the grille off by hand.
  3. Place a towel in front of the refrigerator to clean up any spills that may occur while pulling the drip pan out from under the appliance.
  4. Slide the drip pan forward until is free of the Maytag refrigerator.
  5. Empty the drip pan in the sink.
  6. Replace it with a new one,
  7. Then you reverse the process to reassemble it back together,
  8. Plug it back to the power outlet.
Hope this helped. All the best Elect_Comp
Sep 21, 2011 | Maytag MZD2766GES Side by Side...
Where is the pan where the water drip into
Hi, well the pan you are referring to is called the "drip pan" pretty clever huh?lol well this is located underneath the unit most commonly under the freezer side towards the back. To find it you can pull the fridge out from the wall and unplug it. Then remove the cover panel for the compressor and sealed system. When you remove this panel you will be able to see the drip pan under the freezer. Im assuming you are needing to find this because it is leaking. That is a very common problem due to the pans being made out of plastic and being exposed to temperature changes will sometime cause it to crack. I hope this helped you in any way. Please give some feedback.
Jan 07, 2011 | Whirlpool GS5SHAXN Side by Side...
Whirlpool side by side refrigerator laeking form
Hello
In the freezer section. Behind the lower rear wall is the coils and just below that is a drain. If you will remove any ice and use a coat hanger or screw driver to push down through that hole you should be able to get it unclogged. Take a small cup of water to verify that you have it unstopped and your done.
#225 in the drawing.
I hope this helps.
May 29, 2010 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Have whirpool gold with clogged freezer drain plug to drip pan
Hello, You will be unable to remove the drip pan since it is built in, use a curtain wire, push it down the hole..theres not alot of space but can be done until you feel the clog clear...if it's still iced up use some hot water to defrost the ice before you get to the clog..once you think you got it pour some water down the drain to test it's clear. Hope this helps. Good Luck!!!!
Jul 16, 2009 | Whirlpool GD2SHGX Refrigerator
Need to remove the drip pan under my Kenmore side by side fridge.
Mine is a whirlpool side-by-side ED5GTN which must be the same design as your Kenmore.
There is no way the drip pan will come out without tilting the refrigerator backwards.
The tape is removed, the foam packing, the filter removed, the pan is not flexible enough because the pan broke.
I have worked on this until my hand is bleeding from struggling with this poor design. Custumer service was no help..said, "Well, I don't know."
I'll wait for help to tilt the thing because there is black mold and I want all removed from the bottom of the refrigerator. This design is not only "NOT customer friendly but unhealthy for your home."
Jun 22, 2009 | Kenmore 44273 Side by Side Refrigerator
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
Drip tray full of water, don't know how to get it out to dump
How to remove drain pan on a kitchenAid side by side with water filter .
Nov 11, 2008 | KitchenAid Superba Architect KSCS25INSS...
Don't know how to remove drip tray
hi there,
the drip pan is usually accessible through the front behind the kickpanel. the kickpanel is attached with 2 screws. if you remove the kickpanel, you'll be able to pull out the drain pan.
Oct 02, 2008 | Refrigerators
Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold GS6NBEXRB01 - While Auto-Defrosting, the water drips into freezer from inside Grill
you have a frozen or blocked defrost drain behind the back panel with the vents in it remove the panel and clear the drain at the bottom in the silver pan
Jun 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
425 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
