-   Tired these ideas. Mine doesn't fill for rinse cycle until I let it cool down. Then its fine!!-   Guest
Sep 11, 2008
-   My Bosh dishwasher does not fill with water. It worked one day perfect the next day I run the full cycle then I noticed the dishes never got wet. It sounds perfect otherwise.-   elpapi
Aug 31, 2008
-   Disconnected the water line and checked. The dishwasher still does not allow the water to fill the dishwasher-   Guest
Jun 16, 2008
-   when i turn on my dishwasher it sounds like it is running but no water is cycling and if left on is smells burnt anyone know what the problem could be?
-   missyjo25
Apr 22, 2008
-   Hi My dishwasher has an error 1-   Guest
Frigidaire dishwashers can lose their pump prime and will not fill with water if there is no priming water in the bottom of the unit. To solve this, add several quarts of water to the unit. Let it settle down in the bottom until it stops going down. Start the washer and you will hear this water pump out of the drain and the unit will now fill with fresh water.
I have a GE and I filled the tub until it would not drain anymore...still didn't work. Then I took off the bottom front cover and there was a white trianlgle looking piece. I pushed it down- it is connected to a metal piece that looks like a battery and AHHHHHHH it worked!!
(And no I am not techinical by anymeans- hence the non technical descriptions)
There is a Floater inside the tub protecting against overflow. when it is pushed up (by too much water) or stuck by debris, and does not fall down to its inactive position, it can prevent water from filling.
make sure there is no debris,and move the floater up and down until it falls down in its normal position.
PS : there is a floor cover underneath the door, it has a repair manual glued to it on the back. you can use "diagnostics" mode by pushing a specific sequence on the front panel, allowing you to go through each cycle in an accellerated way.
this is for a kenwood elite ultrawash : there is a floater inside the tub (shape of a mushroom on right front of the bootom of the tub) that controls the incoming water and protects against overflow. if it is activated, it will prevent water from coming in.
check that the floater is not in the upmost position or if it does not drop down when you lift it. the floater must be pushed down. make sure there is no debris blocking it from falling down.
Ps : when i unscrewed the floor cover under the door, i found a manufacturer's repair manual glued to the back of it. there is also some kind of "diagnostics mode" that you can trigger from the front panel.
Check that water entrance valve works (it is an electromagnet valve,loocated at the pipe's enterance to the machine). If it doesn't work, test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new
First try to see if there's a leak somewhere. Cheack to see if there's water in the pan. There's a sensor that shuts off the water supply when there's a leak. There might be a screw loose somewhere that you have to tighten. If there's no leak, the water shutoff valve might be damaged, in which case you will probably have to replace it.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #7
posted on Jan 28, 2007
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
This may sound stupid but... make sure you have taken out the little stopper in the waste pipe under the sink! I had a new kitchen fitted, and forgot about this, and could not understand why my dishwasher would not fill up or drain. Take the stopper out and Bob's your uncle!
Solution #8
posted on Jan 17, 2007
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
I replaceed the inlet valve ($35)and it fixed it.
Solution #9
posted on Dec 30, 2006
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
I have the same problem but the value seems to be fine, I tried checking the water level sensor but I dont know how it should work I does not seem to be a straigh forward on switch.
My GE dishwasher motor hums, and there's about an inch of water on the bottom, but it doesn't fill...
(More)
My GE dishwasher motor hums, and there's about an inch of water on the bottom, but it doesn't fill with water or go into the 'wash' cycle.
Checked power via interlock and start push on front panel, OK. power at electronic programer but but...
(More)
Checked power via interlock and start push on front panel, OK. power at electronic programer but but no led illumination. Progromer looks U/S. Confirm please. Archie Thornton.
I have a bosch dishwasher that has started to work infrequently, the red water light keeps coming...
(More)
I have a bosch dishwasher that has started to work infrequently, the red water light keeps coming on. I have checked the water pump this is ok. Having read previous peoples comment, I think my problem is the float is stuck, because if I tilt the machine a little it works again for a very short time. My question is, where is the float and how do you free it.
Hotpoint dishwasher does not fill with water most of the time. Replaced water valve. Washer fills one time but not the next. A small amount of water enters at first, then stops.
GE GSD6960NSS Stainless Steel Dishwasher: No water...water inlet valve has been replaced.....water float switch has been replaced.......cpu has been replaced...still no water. Washer starts up...then trips circuit breaker.
maytag dishwasher will not fill with water.
Tested valve solenoid with ohm meter...it's o.k. but cannot determine if power is getting to it...what voltage does it run on?
If the timer is not sending power to it, how do I test the timer? Every other function on the timer seems o.k.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
