Toshiba Tecra A3-S611 Freezes
Everytime I turn my wi-fi on, the computer freezes and becomes unresponsive. I tried to reinstall the driver but that didn't work. I even tried uninstalling the driver and reinstalling it. When the Wi-FI is turned off the computer works fine but I am unable to use high speed now.
  • 72 Answers
If by "turned off" you mean with the switch, the wireless adapter itself is probably bad.The cheapest solution is to buy an external wireless adapter.
Posted on Sep 10, 2008
Can you show me a link to download ethernet controller for Toshiba Tecra A3 S611? Thanh you so much
http://www.bioticaindia.com/tecra-a3-s611.html
or
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1039003&rpn=PTA30U&modelFilter=A3-S611&selCategory=3&selFamily=1073768664
Aug 20, 2010 | Toshiba Tecra A3-S611 Notebook
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
I re-installed Windows XP, now none of the USB ports recognize anything. Any suggestions?
Hello
Have you installed the chipset drivers after you reinstalled Windows XP?
If not, you will be able to download the drivers HERE.
Let me know if you have done this already.
Kind regards
Andrea
My computer doen't want to show volume taskbar
make sure you have audio driver installed, if yes go to:
Control Panel> Sound and Audio Device> tick Place Volume icon in the Taskbar
May 23, 2010 | Toshiba Tecra A3-S611 Notebook
Where to find driver for touchpad scroll toshiba tecra A3-s611
To Enable the Pointer Device, go to, Control Panel, click (Mouse) in the Hardware and Sound category. Go to, Device Settings, in the (Devices) block, click on, and Highlight; the item you want to (enable) this being the Pointer Device. Click the Enable button, just below. Be sure to (Click) on the Apply button, click OK. You may need to Update Drivers. Click on Hardware, click Properties, click, on Driver. If the, Update Driver (block) is not Grayed-out click Update Driver, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. I hope this Fix it. paul7of9
Jan 21, 2010 | Toshiba Tecra A3-S611 Notebook
How to replace ac jack toshiba tecra a3=s611
Need to remove the motherboard to replace.
Dec 07, 2009 | Toshiba Tecra A3-S611 Notebook
Sound problem
It is possible that there maybe a speaker fault, ut it is equally possiblt that there is a motherboard fault. It would need to be checked by a qualified engineer.
Jun 21, 2008 | Toshiba Tecra A3 Notebook
Battery
That means that it has not recognised the new hardware yet, you need a skilled person to have it recognise or the battery is not compatible to your machine - need to buy a correct battery.
Dec 31, 2007 | Toshiba Tecra A3 Notebook
Computers & Internet Logo
285 people viewed this question
David Payne
David Payne
