Question about Kenmore Kitchen Ranges
The back burner of our Kenmore 30" electric free standing stove model # 911.94401301 is not working the coil is working it will heat up I am curiouse if it is the plug under the hood and is this something that I can fix
  • 550 Answers
This IS something you can fix
There are three likely causes, in most common occurence
there are fuses in the rear control console that blow
the socket does wear and require replacement
the temperature controller wires come loose, or the control fails.
check first for fuses
second swap the cables from the controller of the burner that doesnt work, to another controller to test if it is the controller or the socket.
  • swap cables with power disconnected and do NOT leave bare cables unsecured even while testing, better a live repairer, than a live wire
if the burner then works the controller is dead
if the burner still does not work, the socket is dead
the local parts store, or even a hardware store, will have the parts, even if branded frigidaire or ge or generic instead of kenmore, (Sears service is expensive and slow) many models of stove use the same socket, element, controller, clock, circuit board
Posted on Sep 10, 2008
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
I have a Kenmore model 790.95592 30" free standing range with self-cleaning function that I think has an eletronic function problem. The oven burner elements start on its own and fluctuates to danger
Dear Ernie,
I am very glad you asked. As a retired firefighter, and an electrician, I can say you were just about to have a fire.
The most likely problem is a "meltdown".
Something has melted, and is causing a direct short circuit.
Lightning or power surges can do this.
Please turn off the circuit breaker, and unplug, or disconnect the wires to the back of the stove.
Start by looking where the wires go into the back of the stove.
See if there is visible burning or smoke or blackness.
You might be able to fix this, buy re-wiring the stove, but if the controls are melted, you may be needing a replacement stove.
An electric meter will be really helpful to find the problem, but with the way you have described this, you may be able to see or smell the burned part.
God bless your efforts.
Jul 10, 2017 | Kenmore Kitchen Ranges
I have a kenmore 953 freestanding stove, my wife was making pizza and the oven made a strange sound, the display is no longer working, the oven stopped heating, and she attempted to turn on the burners,...
If you will type "SearsPartsDirect" into your search engine, you can then enter your model number and you will see all the parts of your stove.
What should have happened was, either an element failed, or the element wire connection inside the wall of the oven failed, or a wire has "toasted" in the electric box inside the back of the stove.
You will need to take the oven out (away from it wall, perhaps) & give it a good inspection with an electric meter to find out where the problem lies.
Oct 02, 2017 | Kenmore 9535 Electric Range
Kenmore Elite Freestanding Electric Range - Cooktop not working
Your stove probably requires a separate 20A circuit with 12 ga. wire.
May 19, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore stove oven does not shut off
Wow, this post is going to be extremely late. Actually, I was able to get a new control unit for my Kenmore gas range from Sears Parts Dirext for $156.06. That includes shipping and tax. The burners work without it. We just cannot use the oven until the new board comes in. It's very easy to replace. Remove the panel screws on the back (just the top) and you have access to unplug the unit and remove the 4 screws holding the assembly in.
Jun 05, 2009 | Kenmore Ovens
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Kenmore electric stove model c880.6383880 left front burner does not work....it is not the element itself as it heats up on another burner.
hi,
sounds like you have the old-style coil elements on you stove.
your problem is the switch under the element, called the infinite switch. i would suggest to have a technician replace it. they usually charge for the labour but if you have never done it before, it's money well spent.
Aug 19, 2008 | Stoves Kitchen Ranges
Kitchen Ranges Logo
238 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
