Question about Curtis-Mathis CM27101S TV
Picture too big
There is no setting for view on tv. Its like that all the time, even after being off.
  • Boston Sam Nov 08, 2007
    Picture appears to be "zoomed" in. There is no zoom button, though this model does offer what is known as "extra view," which squeezes more picture (about an inch) into view, hence the 28" width. Kind of a "zoom out" feature, if you will. A couple of months ago the picture began suddenly popping into a zoom-like condition. Turning it off and on again quickly often corrected it, but this no longer works. This occurs regardless of input (cable, dvd, etc.) Thanks for any advice.
    President:
  • 3,130 Answers
You mean too big from side too side or top to bottom?? if its all the way around is there a zoom button on the remote??? if ita too big from top to bottom a part might have changed value in the vert sweep curcuit. You could very carefully take off the back and find a small pot or control in the vert cuircut and bring down the picture But I dont recomend this if you have no knowlege of tv curcuitry.
Posted on Apr 04, 2006
Flat Screen Insignia TV picture too big? How to adjust picture size?
When the picture is too large there are three possible solutions at least.
Starting with the simplest two: There are buttons on the remote controls (cable/satellite and television) that control the picture size. On the cable remote it is usually on the bottom, and it says hd zoom. Press it and it will size the picture down for you. On the television or satellite remote it might say view mode, picture mode, format or aspect.
Now, the more difficult solution if the above doesn't work: The settings might not be right in the cable box/set top box. If the television is a 720p television, make sure the cable box/set top box is set for 720p and not 1080i even though they're the same (yes, yes I know). Also make sure you are not connecting a cable/set top box to the coaxial rf input when you have the capability to connect to a component or hdmi cable. I hope this helps.
Dec 01, 2012 | Televison & Video
Tiny "guide-size" screen remains when I'm out of guide
HI,
I'll let you know if there is a mnual available online for your model.So that you can find out some troubleshooting steps.
Apr 16, 2008 | Philips 42PFL5332D 42 in. LCD Television
Tv picture is getting too big for the screen. Can the picture size be reduced?
Hi, well this is most likely a Aspect Ratio issue, this can be set via the TV's Menu. You simply need to adjust this aspect ratio, to suit you viewing requirements.
It is all explained how to do this in your user manual, link provided below. http://www.devicemanuals.com/guide/Television/Symphonic/Symphonic-ST420FF-20-TV-Owner's-Manual-T0RVek16az.html
Sep 29, 2010 | Symphonic ST420FF 20" TV
No TV Picture
Unplug,replug an hour later,might reset to factory setting.Tries stop all timer setting.
Dec 29, 2009 | Televison & Video
PICTURE IS TO BIG
You probably have the TV set to "Stretch" you can change this with a simple click of your remote control. Look for a button that says "View" or "Zoom" on it
Nov 27, 2009 | Mitsubishi Televison & Video
My tv had out of focus. It appears on letters ,football view ,and all small picture.in big picture the view is very good.
Maybe lens need adjustment or picture setting is set wrong, consult manual for troubleshooting.
Mar 25, 2009 | LG Televison & Video
Picture quality
Are you viewing HD or standard definition.
Generally, LCD tvs don't do well with "standard" signals, since they're designed for HD.
You may get a slightly better picture by replacing the cable that connects from your TV to cable box, and cable box to wall. However, if you're not watching HD, it's unlikely that you'll notice the better cable making a big difference.
Mar 19, 2009 | JVC LT-42X579 42 in. LCD TV
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
View timer is stuck on
take your set to a tech your problem is more a technical problem that sounds as you are having a chip problem that controls the timer
Feb 16, 2007 | Sharp 55R-WP4H 55" Rear Projection...
Phillips Big Screen Older Model
It means the fluid that cools each picture tube is low in the green but where did the fluid go,remove the back cover and check for a fluid leak towards the front side of the chassis and if any it should be right below one of the picture tubes.The description of your problem tell us you have a rear projection set but the heading shows a direct view tv.?????????? Since it was move the leak is only a possibility there could be other reason.Be careful and be sure set is unplug.
Sep 29, 2006 | Philips 32RF50S 32" TV
Curtis-Mathis CM27101S TV Logo
243 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Stan Skaggs
Stan Skaggs
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
