Question about Onkyo TX-DS989 Receiver
Onkyo TX-DS989 not staying on
Usually my receiver works just fine. But now even though the standby light stays on, when I turn on the power it stays on for 3 seconds and then turns off. I tried using a different power cord with no success. What do you think?
k
  • 5,568 Answers
This sounds like the action of some protection circuit that is monitoring some condition or voltage that isn't within its design limits. If it was mine, I'd look for an Onkyo forum to see if others have experienced the same problem.
Posted on Jan 08, 2009
Onkyo TX-SR805 Receiver power-on button not working, only the led red light indicator appears. Tried to reset by holding/press vcr/dvr & standby/on button, no result. Please help me solve this problem
Hello, Sorry, if the receiver does not turn on we can't do any troubleshooting. I suggest having your receiver serviced or traded in. Thank you, Onkyo USA
Feb 26, 2017 | Onkyo Audio Players & Recorders
Onkyo TX NR515 .. when in standby mode .. light is not coming on .. everything works fine .. i must have pressed something by mistake but cant work it out what ... on the display panel in standby mode...
If Zones are turned on or, if a mobile device connected to the Front Input is charging (MHL), the HYBRID STANDBY indicator won't light. See the TX NR515 owner's manual at http://filedepot.onkyousa.com/Files/own_manuals/TX-NR515_English.pdf for more info.
Feb 19, 2015 | Onkyo TX-NR515 AV Receiver
TX DS989 turns off after 3 seconds
Sorry but it does sound like an Amp failure and testing the unit for other electronic component failure will be needed
Jan 03, 2014 | Onkyo TX-DS989 Receiver
When I turn on my Onkyo TX-DS 989, the standby LED does not light up and you can not turn on the amp, but after about half an hour the LED lights stby and then you can turn on the amp and everything works...
The trouble is almost certainly bad capacitors in the power supply. As they age they become very slow to charge up (think of them like buckets that store electricity for other parts to draw on, and it's taking them much longer than normal to fill). As a result it's a while until the rest of the circuitry starts working properly. But once they've charged, the thing works like it should.
If you know someone with some electronics skills, they could check the capacitors and replace any that are visibly bad or don't measure correctly. Or you could see about getting the receiver serviced if you have a shop in your area. Musician's supply stores are a good place to check, or ask retailers if they have anyone they suggest. Since the receiver is basically okay otherwise, having this repaired would probably be worthwhile.
Mar 04, 2011 | Onkyo TX-DS989 Receiver
Upon powering up my Onkyo TX-SR605 receiver, it enters Audyssey setup mode even though the microphone is not plugged in. Even if I plug in microphone and remove it, it still stays in Audyssey mode and I...
I have the same problem and it is not speaker wires, cables, or dumb remote codes (really, remote codes.) I'm taking mine in for repair, and not reliying on straw grasping, speculative solutions.
Jan 25, 2011 | Onkyo TX-SR605 Receiver
Won't turn on.standby light on,fuse under cover is good.what next? onkyo tx-sr605
The only thing to test would be to disconnect all speaker wires at the receiver then turn it back on. If it still won't turn on, it's an internal power supply issue and will need service. If it turns on, post a comment and I can walk you thru further troubleshooting. Hope this helps
Dec 19, 2009 | Onkyo TX-SR605 Receiver
Power works but receiver will not stay on
The outputs are blown and will require repair.
Dec 17, 2007 | Onkyo TX-DS575 Receiver
Brand new Onkyo Tx-sr605 won't leave stand by
If the unit will not leave standby I would remove all power, disconnect *all* connections at the back, reconnect to a power source and try powering on. This will eliminate any connection causing the Onkyo to stay in standby due to a short. If it still will not enter power-on mode, you may want to look at the power source (is it properly grounded?), but beyond that the unit probably needs to go back.
Nov 03, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-DS989 Receiver Logo
351 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
