Question about Microwave Ovens
GE spacemaker went belly up this morning
My twenty year old like new GE spacemaker II has run like a champ for all these years. My old friend started to heat my coffee this morning then all of a sudden went "psst" and died. Any hope it could be repaired or is it all over and I need a new one??
  • Brierwood Sep 17, 2008
    Thank you for replying to my problem. We took the outside covering off and found the mini manual as well as the fuse. We checked the fuse and for about $3 we tried new fuses. With a new fuse, the same thing happened: pushed start and after about 15 sec. blew the fuse. The second fuse blew as well. Well, long story short, the clock had been dead for some time and the people who repair microwaves out here wanted $55 just to trouble shoot the problem, not counting the cost of whatever part needed replacing. So we went out to Walmart and bought the same size, not a spacesaver, but 1.1 cu. ft. GE for under $60. Too good a deal to pass up! Thanks again for your amazingly indepth reply. Gail
  • Microwave Ovens Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 16, 2008
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge model JVM1850. It is 6yrs old. Today it suddenly did not heat a frozen small item thru. Does this sound repairable or do I need to consider replacement? It is above oven.
well!!!!!! its 6 years old,,,,my bet is the manatron has failed,,,and thats a pricy part to buy and have fitted,,,
you may find in the long run its cheeper to just buy a new microwave,,at least it would be a new one and not 6 years old! and not a patch up job
Jun 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating
If the micro is over 5 years old you may need to buy a new one.
Jun 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven just quit. Have checked fuse and plug. Have had no earlier problems. Do these ovens just ''wear out''? It is 8 years old. It is a GE Spacemaker. (November 2002) GE Spacemaker Serial...
yes they wear out. usally the first part to quit is the unit inside that creates the microwaves called the "magnetron" over time they will wear out, and so will the circuitry that runs the entire microwave, some will last 8 years like yours, some only a year or 2. 8 years is pretty good for the life of a microwave. but yea, its time to get yourself a new one. good luck to you
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It is making a lound noise and no longer heats
heatman101
dgh
Oct 24, 2009 | GE Profile Spacemaker II PEM31 Microwave...
Microwave oven stays on continuously and won't heat food.
Spacemakers have had problems with there magnatron, part is around 170.00. Depending on the year it is covered under a warranty however the labor is not. I have replaced 3 spacesavers for people already due to this issue. Unit runs but will not heat.
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker II microwave. sensor error lite comes on
Sounds to me like you have a bad magnetron tube. Call GE Factory Service as there is either a 5 or 10 year parts warranty. Or schedule a service call online at www.geappliances.com
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Loud and not heating
If it's less than a year old, it's still under warranty. If it's just over a year old, GE will still cover parts, but you'd have to pay for labor.
Contact them at http://www.geappliances.com/service_and_support/contact/
The most likely causes are a shorted high-voltage diode or a bad magnetron.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 13, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
96 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
