Printer 1p4000 saying needs new yellow cartridge and it's been replaced- yet the sign is still coming up! How can I reset the printer so it knows it's got a new cartridge. thank you Rachel
    Problem Solver:
  • 20 Answers
If you find were your printers are installed then you should be able to open up all of the options like run test page etc and on there it should have install new cartridge or something like that wen you get to that option install the cartridge and it should ay press ok (on the printer) wen the new cartridge is installed if you do press ok it should reconize that there is a new cartridge installed, if it doesnt then check that the cartridge is fitted in properly
Posted on Sep 11, 2008
Replaced empty ink cartridges in hp c6280 printer but computer says they're empty. help?
Did you remove the protective cover / tape, you re put the cartridge.
Jul 25, 2012 | HP Photosmart C6280 Printer
I received an out of ink/need to replace yellow ink cartridge. message. Although I replaced it with a new cartridge, the printer is not acknowledging that I have changed it and continues to say I need...
I'am facing the same problem. I have no idea of any effective solution. Actually I have tried everything that is mentioned in several threads on the net: different types of the printer reset, CMOS reset as well, but without luck. I'm afraid it won't print in colour anymore. It all comes down to some electronic issue I guess. That's why I'm not able to cope with it.
Dec 13, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have a HP Officejet Pro L7680 and have enjoyed a year of problem free use. Now the printer says "Ink Cartridge Problem" :The following ink cartridge appears to be missing or damaged" ...
Hi
You need to replace the Yellow cartridge
with a new one couse the old one either
has expire or has problem with the chip
on cartridge
ps vote us to keep us alive
Nov 06, 2010 | HP Officejet Pro L7680 All-In-One InkJet...
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
Won't accept new ink cartridge
Look inside where the ink goes, there is a spring on the right side, if it comes out of place it can cut the ribbon cable at the rear. If thats the case, you need a new printer.
Jul 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Says the yellow ink needs replacing,have a new ink cartridge in
pulled plug, removed yellow cartridge, cleaned point where yellow ink goes in, put plug back in and it worked.........Thanks
Jan 27, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer won't recognise new ink cartridges and correct itself.
Hi..
try to reset the machine.
disconnect the usb and power cable...and press and hold down the power button for 45 seconds and then reconnect all the cables and try again...
or try to clean the print heads...still does not work...could be an issue with print sensors..needs to be replaces.
Regards,
debroy
Nov 25, 2008 | Brother MFC-3240C All-In-One InkJet...
Canon pixma ip 4200 printer problems
in the printer driver there is a option that whenever you install a new cartridge it has to be reset otherwise it shows the message the above you quoted. one more option is there that is change the chip of yellow cartridge and black, after doing this please whip circuits of the cartridge and printer carriage block before installing the cartridge
Apr 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
