Question about Dell Dimension 2400 PC Desktop
Reformat????????? I put my windows xp cd into my drive and made sure my computer was booting from cd. I went through a process of repairing. I ended up with the same old black screen that says to type a password. Now it's even worse I can't even type anything. I think my keyboard isn't working. Should I go through the process again and do something else besides repair? Help????
    Scholar:
  • 65 Answers
Whenever I install I prefer to do a fresh install and not select repair. I find I am much happier in the long run, unless of course there is data on the drive you are trying to save and then I will try to use repair get the data I need and then do a fresh install.
You can try repair again and if it happens again then I would suggest selecting to format it, do a fresh install, however your installation disc prompts.
If you need the information on the computer and know how to use DOS you can create a boot cd and use a flash/usb/thumb drive to copy the data you want to save. I you need to do this let me know and I will tell you what you need to do.
Posted on Sep 17, 2008
Windows xp is not starting
Windows XP is a fairly stable and secure operating system, but errors and other problems will occur from time to time. Unfortunately, some of these errors can damage or corrupt important system files and can lead to Windows XP not booting up correctly. You can repair your Windows XP installation using a process known as a "repair install," overwriting the damaged system files with new versions from your Windows XP installation disc. The repair install process takes approximately one hour, though a large portion of this time will not require any input from you.
1,Start your computer and place the Windows XP installation disc in the drive. If the computer is crashing upon attempting to boot, allow it to restart; otherwise, reboot the computer manually.
2.Press a key to boot from the Windows XP CD if prompted to do so when the computer attempts to boot again. If you are not prompted to boot from the CD, restart the computer again and press the indicated key on the initial BIOS screen to access the "Boot Order" or "Boot Sequence" menu. Select the CD or DVD drive containing the Windows XP installation CD, then press a key when prompted to boot from the disc.
3.Press the "Enter" key on the initial Windows XP welcome screen and press "Enter" again to begin setting up Windows XP. Do not press the key indicated to launch the "Recovery Console," as the Windows XP recovery console is not used to repair corrupted XP installations.
4.Accept the user agreement and wait while the setup program scans your hard drive.
5.Press the "R" key when the Windows XP setup program lists the installed version of XP that it detected to begin the repair installation. If you have more than one version of Windows XP installed, make sure that the proper version is listed before pressing "R."
6.Wait while the Windows XP setup program copies files to your hard drive and begins the installation process. The installation will take 45 minutes or longer, depending on the speed of your computer, during which time all of the Windows XP system files will be overwritten.
7.Confirm your user information as well as the date and time settings on your computer, and enter your Windows XP product key when prompted. Allow the operating system to connect to the Microsoft authentication servers to activate itself.
8.Reinstall any hardware drivers and XP Service Packs that you had previously installed, as your copy of Windows XP will have reverted to the basic installation you had when it was first installed.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
I was told to reformat my computer. I don't know how. Can you help?
Actually, it's not recommended without know how to do it since it should be done by a professional or by an experienced engg/tech. Well, before you decide to format, you'll need a Windows cd, if you wish to install Windows xp, you'll need a Windows XP original CD or if you wish to install Windows Vista, you'll need a Windows Vista DVD, in the same way with Windows 7. Note: Formatting means wiping out everything from your computer, usually C drive so that you'll be able to install another copy of Windows, which means you'll first format the C drive and then install a new copy of Windows, without Windows being installed, you computer will never run, it's similar to a useless or dead machine. I don't mean only Windows, same conditions apply with Linux or Mac.
If you want to try yourself following the instructions, let me give you few links, but it's not a simple and short process, and I won't take the risk if you fail (this is why I'd mentioned that it's a job to be done by a pro). Here are few links from BlackViper.com regarding Installing Windows. Follow the link/s and follow the instructions, there might be several pages, so make sure you scroll down to the bottom of the page/s and click "Next Page" if you are done with the first/previous page. Before you begin, please read the full tutorial/s so that you will know what exactly you're going to do with your computer. If you can still boot up your computer, make sure all the files are moved from C drive to another partition or I would recommend backing up your computer's files.
1. Windows XP install guide.
2. Windows Vista install guide.
3. Windows 7 install guide.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 01, 2011 | Microsoft Computers & Internet
How to reformat window xp
Reformat the Hard Drive in Windows XP
  1. To reformat a hard drive with Windows XP, insert Windows CD and restart your computer.
  2. Your computer should automatically boot from the CD to the Windows Setup Main Menu.(If not, press F2 or DEL and choose first boot device CD or DVD)
  3. At the Welcome to Setup page, press ENTER.
  4. Press F8 to accept the Windows XP Licensing Agreement.
  5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  6. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
  7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
  8. Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
  9. You have now sucessfully reformatted the hard drive with Windows XP.
Jan 02, 2011 | Microsoft Windows XP Professional
How to reformat back to windows vista ?
You need a windows Vista disc. Insert the disc and follow the prompts. I would format the hard drive instead of upgrading do a new install. The best way would be to go into your bios and make sure the boot device order has the cd-rom booting before the hard drive. Then put the disc in and start the computer, when it says press any key to boot from cd hit any key and let it load and then follow the prompts to install.
Nov 27, 2009 | NEC Versa VX Notebook
How to reformat acer travelmate 2480?
run install from windows cd back up drivers first if you don't have a drivers cd
Sep 17, 2009 | Acer TravelMate 2480-2153 Notebook
Windows not booting
Regarding on your problem, the main issue their is the booting problem of XP after you delete the fedora operating system. That's common problem especially when the computer are in dual boot OS then you delete the other OS. Now, the reason why it usually fall into this problem its just because the XP is your core OS then you install Linux Fedora inside in XP so whatever changes you have done in fedora particularly deleting Linux OS inside XP affects the overall performance of your XP and eventually if you delete the Fedora without proper unistallation process done by Linux OS then the Boot Loader of your XP will also corrupt or delete that's the main cause of boot failure in your XP OS. Now the best solution there is to repair your XP by inserting the XP CD Installer and boot the CD to repair your OS or you can reinstall the XP OS without formatting the storage to prevent the lost of your data that has not yet already copyed a back up.
Please do this recommendation to save and restore your XP.
thanks
Sep 04, 2009 | Microsoft Windows XP Professional for PC
Dell Dimension 4600 stalls during boot
Turn the computer's power on.
Immediately put the original Windows XP CD into the drive.
Tell the computer to boot from the CD (not from the hard-drive).
Does it start to boot from the CD?
Do you get as far as the "repair/install" boot-screen?
If so, your basic hardware is OK, and turn your computer off,
rather than choosing "repair" or "install".
Then, it's probably either the hard-drive that is failing,
or the installed copy of Windows XP is fuddle-duddle-ucked up, so that it cannot finish the "Windows startup" processing.
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
Hello the hard drive of our laptop needs a full reformat so i can reinstall xp but how do i format it without a working opperating system? thank you
 You can do a full reformat right from the windows xp install disk.  Put the xp disk in the cdrom drive and restart the computer.  Upon restarting a message will come up ( Hit any key to boot from CD )  Hit any key,  the files will load then you will be able to format the hard drive and also load windows XP.
    If for some reason your system doesnt boot from the cd, you might have to go into the Bios and change the boot order from the hard drive or the floppy to the cd so the computer will boot from the CD first. Hope this helps...                                                           Joe > Data Miner <
Oct 31, 2008 | Computers & Internet
Want to erase drive
If your Laptop is purchased with Recovery Disk, you can use that disk to restore the default setting of your laptop. It usually FORMAT your hardisk and erase all programs and files saved on your Hardisk. If Recovery Disk is not available then you can simply use your provided Windows Installer to format your Laptop and install a Fresh Windows on your Laptop, be sure to format the Whole Disk Drive to erase the files.
Jun 11, 2008 | Dell Inspiron™ E1505 PC Notebook
Dell Dimension 2400 PC Desktop Logo
Alun Cox
