Question about Samsung SyncMaster 955 DF 19" CRT Monitor
Out of focus monitor - 955DF
I have a samsung 955DF monitor that is out of focus and the screen is kind of faded out. Is there a way to boost the brightness and contrast beyond the limits of what the onscreen menu can do? I've raised the gamma on my video card but even that's not enough. any suggestions?
  • 30 Answers
Edge-focus is notoriously tricky on flat-screen picture tubes. I have not found anything on adjusting the focus for this model. it seems to be a common problem, though it seems to be more of a sample-defect problem rather than a poor design; a replacement should be OK.
Posted on Apr 05, 2006
My wife was on the comp. and the screen faded by pressing the on /off butten it lights up and fades away you can see the icons but very faint it screen is a samsung flat screen
If it is a LCD screen, it appears that the lcd inverter is going bad. It can be repaired, however with the lower costs of lcd monitors, you might be better off buying a new monitor.
Jul 27, 2014 | Samsung Office Equipment & Supplies
CRT monitor screen is out of focus.text and other images looks blurry
This kind of symptoms can be correct by the focus adjustment at the flyback transformer. FBT mostly has two control knob (Focus and Screen), focus is usually at the top one like in the sample picture below.
Open the back cover of your unit and then locate the FBT. Power on the unit and try to adjust the focus knob.
If the symptoms can't be cured by the this step, this is an indication that the CRT socket is already faulty. You have to replaced this parts and then make some adjustment at the focus knob of the FBT and your unit will back to normal again.
CRT(picture tube) socket
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jul 14, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Screen went black! Briefly comes on, very faded, then blacks out again. Haven't had for more than a year...
I've had a similar issue with my Samsung screen awhile back. It should be that your monitor's power supply unit has degraded and needs replacement. You will have to send it to Samsung for repairs.
Mar 04, 2011 | Samsung 933SN Monitor
Can I hook the SyncMaster 955df to my laptop for a larger viewing area
Hello there :
Yes you can i have done this on several laptops to troubleshoot the screen all you have to do is to hook up the end that you would normally hook to your computer in the video port on the laptop and plug in the monitor and then turn on the laptop and you will now be able to see the laptops normal screen on the monitor that you just plugged in ok
I hope this is very helpful for you
Best regards Michael
Dec 21, 2009 | Samsung SyncMaster 955 DF 19" CRT Monitor
Screen fades to white
Most probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver IC thus you could only see white display. A replacement of LCD panel is the best solution. best regards
May 25, 2009 | Chi Mei Corporation 736A (Silver Black) 17...
Focus on monitor
Try replacing the filter capacitors on the video circuit.
Apr 28, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Fade letters
Perhaps what is needed is to re-adjust the focus/screen controls. They are located at the FBT. A friendly reminder, standard precautions applying when working with live HV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 08, 2008 | SAMTRON 55V 15" CRT Monitor
SyncMaster 551V poor colors
Hi, Based on your post/description and assuming that the CRT monitor does not have any failed component(s), it would appear that you have a weak picture tube. If relatively new, claim warranty and have it replaced; if in service for some time, it may require adjustment in the Screen and Focus controls of the FBT; if really old, you may need to boost the color drive transistors B+. The second and last suggestion above would require that you be familiar and comfortable working with TV/Monitor units, high voltage and working with the unit powered on. If you are not comfortable performing a do-it-yourself, perhaps your best bet would be to seek the services of a qualified professional. Hope this be of some help/idea. pls post back how things turn up or should you need further information. Good luck and kind regards.
Sep 16, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Samsung SyncMaster 955 DF 19" CRT Monitor Logo
147 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
