More than likely it's not all the bulbs that are burnt out. Your head lights work like a relay if one bulb is bad then none of them work. Try looking for the bad bulb (this will require you to pull the head light assembly a part to look at the bulbs) what you are looking for is blackening around the clear part of the bulb, also if you pull the bulb out of the socket and give it a bit of a shake does it make a rattling sound? If so then it's bad.
In regards to your left turn signal have you replaced the bulbs or check to see if they are burnt out as well? The also operate as a relay and will not work if one is burnt out.
You may be right about it being a switch. If you have the time, take the door panel off which can sometimes be a pain, **** worth it. Check to make sure the wires are still connected properly. If they are then i would look in and around the window tract to see if there is anything that could be impeding the window from going down. Other wise it could be a bad button system and just the drivers side button is shot. You may have to replace that. Hope this helps. Good luck.
