Question about GPS
JENSEN NVX225 WON/T TURN ON IT DEAD POWER TO UNIT IS GOOD BATTERY CHARGES UP
  • conniee Apr 17, 2009
    Battery does not hold it's charge. Where and how do I replace the battery.
2 Suggested Answers
riceski
  • 1851 Answers
SOURCE: Garnin 260w slide switch will not turn off unit.
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Posted on May 08, 2010
My Asus Eee PC 1001PXD battery won't charge. The charges light is on but nothing happens and now the battery is completely dead and I cannot get my notebook on
Your problem is far more than the battery. Your problem is the power cord. Laptops for the most part will work off the power cord even if the battery is dead or even if the battery is not in the laptop. Your power cord charges your battery and if it is bad it will not charge it. You've been working off your battery even though you might have had the power cord plugged in, but if it's bad and not charging the battery, the battery drains and then you can't get the laptop to power on at all. Go purchase a ac adapter and power cord that is designed for your system. Don't buy one that some of the big box stores sell that has a an interchangeable plug at the end designed to fit just about any laptop. Those will eventually burn *********** board out.
Mar 20, 2012 | ASUS Computers & Internet
Vm9424 unit will not power on pressed reset button and it beeps and lights around function buttons come on and go back off fan comes on for about 10 seconds and turns off checked power ground fuses.is...
Hello lumberjack623,
When the jensen starts acting this way, it is simply a power problem. The device is not receiving power from the main source. The battery is weak and need to be charged before the unit can turn on once again. The battery power is too low to turn the unit on.
Try to check the power source or the connection to the power source. It is not charging the players battery. You need to have the connection port replaced. Also the power connection needs be checked.
The battery is simply weak that is why it goes right off when it comes on.
Hope this was helpful to you. All the best Elect_Comp
Sep 06, 2011 | Jensen VM9424 Car Video Player
2001 Yukon SLT, engine will not turn over - friends think it's the alternator. Battery is 2 yrs old. My friend tried to jump start it, that did nothing, still won't stay turned on. I got the...
Hi there !
I won't say its an alternator problem because the alternator only charges the battery when its on, And it should start with the jump cables even if the battery and the alternator are bad. your Issue is not clear. Does the car start when you jump it ?
Aug 15, 2011 | 2001 GMC Yukon Denali
I have a nvx225 gps how do i update this unit
Unfortunately the Audiovox NVX225 (which was also marketed under the identical model number for the Jensen brand name) has too date not had any map updates made available. For whatever reason the manufacturers never got around to updating their maps after selling these, as well as many other units to consumers. If you take a look on the Internet there are all kinds of forums and help sites that are full of people complaining about the fact that their GPS units are over 5 years old and have never been updated. Even with all of these complaints made public the companies still chose to not make the updates available.
There are websites that will give you files to download that will completely replace your GPS operating system and then allow you to download and install update map information that they have created. The real drawback to that is there is no guarantee the hack will work and it could render your unit totally unusable. Should you decide this is something you want to try you can do a Google search for your model number and the word hack. You will then be given a number of websites that will have the hack files available.
May 14, 2011 | Audiovox NVX225 Car GPS Receiver
My Jensen nvx225 its frozen The Jensen screen comes up and that is about it. I have tried resetting with no luck. Also, the power on/off button does not work
You are in a protectr mode. This stereo will do this in order to save itself from damage when it picks up that there is something wrong. Most likly it is a simple bad speaker, or a bad ground. Unhook your negative battery cable then check stero connections in back, fuses, and then all your speakers.
Apr 17, 2011 | 2000 Chevrolet Cavalier
Phone was dead says battery charged...power off why wont it work
If the phone charges the battery as it is displayed on the screen when a charger is plugged in but does not power on, the power button/switch is faulty. Have it checked and replaced by a qualified technician.
If the phone doesn't charge the battery, the battery is probably drained or dead. To verify, grab a voltmeter and check the battery voltage. Set the selector knob to 10V DC. Voltage reading of less than 3 volts indicates the battery is drained or dead. Use a known good battery.
If the battery is good but the phone still does not turn on, it is dead and have it checked by a qualified technician.
Nov 26, 2009 | LG RUMOR Cellular Phone
Battery dead unless pluged into computer. Charges
Friend, the power switch is damage thats why the charger acted as switch. replace the power switch
Jul 17, 2009 | Sony NWZ-E436F MP3 Player
Jensen VM9410 - Stopped Operating All Of A Sudden
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
Jun 24, 2009 | Jensen VM9410 Car DVD Player
Jensen nvx225 navigator and can't get it to work
I just recieved mine as a Christmas Gift. I am having EXACTLY the same problem. I, also, have tried the reset button that is located in the back of the unit. I'll have to get back to you when/if there is a resolution.
Dec 12, 2007 | Jensen VM9510 Car DVD Player
GPS Logo
131 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
