Question about Proview InnoVision VM541 (White) 15 in. Flat Panel LCD Monitor
Monitor colour problem
My monitors colour balance seems to have gone wrong. It?s display is dominated by blue and it seems to be unaffected by the monitors built in colour adjustment settings. I have also noticed that the shade of blue changes depending on what is on the screen, for example if a window is maximised the shade of blue deepens. I have tried the monitor on different computers so I know it is a problem with the monitor itself rather than my graphics card. I can?t seem to find any information on this problem and pro-view simply gave me a fixed price for repairing it which is high. Does anyone know why this has happened and if it is repairable?
  • Anonymous Mar 29, 2008
    my computer display seemed to be showing blue ,green colour but not pink and red colour whats the pro behind this please send your views?
  • Anonymous Nov 25, 2008
    yeah, it sucks.
  • 30 Answers
I assume you tried another monitor cable as well, if you didnt, it is one of the most common causers of unbalanced colors. if you did, my guess is you have a bad color gun. It's a very common problem. in this case, a trip to the local repair shop is necessary. before you do, you can try pulling out the VRAM and reinstall it. its a long shot, but you got nothing to lose. good luck.
Posted on Apr 04, 2006
I have a lg w2234s monitor and the colour seems to have gone funny, it has a green shadow where black should be. Its not my video card because i have tried a diffrent monitor and it works fine
Sounds like the colour balance is out of adjustment. There maybe adjustment controls accessible through holes in the rear of the monitor, if not, new monitor time.
Mar 27, 2011 | Computers & Internet
I hve a sansung 48 v monitor. the screen is very much redish
CRTs use 3 "guns" to mix the 3 "primary" colours (RED, BLUE, GREEN). One of the other guns has stopped working, leaving the RED gun as the "dominant" colour.
Spend $30, and buy a pre-owned 15" LCD monitor.
Or, spend $100, and buy a new 17" LCD monitor.
May 26, 2010 | SAMTRON 55V 15" CRT Monitor
My E771 monitor colors suddenly shifted with
Possibilities:
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
Picture changed to a blue dominant picture
disconnect the monitor from the system and check if all the pins of the cable are not damaged. if not damaged, then check the device manager for exclamation marks, try and reinstall the drivers
steps to open device manager;
click Start select Run type Devmgmt.msc press Enter
Apr 21, 2010 | Acer 22" X223w LCD Monitor
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I can't see the colour red on my monitor. it turns up as grey. it is dominant in green and blue
Hook up a different known good working monitor to the computer. If the good monitor works then you know its the original monitor that is bad.
If the good monitor gives you the same problem then you know its the video card at that point that is bad.
Let me know if the original monitor that is giving you the problem is an old crt monitor or if its a newer LCD monitor?
Jul 04, 2009 | LG Computers & Internet
I too have d same problem..
unscrew the monitor plugs and re seat, often these plugs come loose and the pins fail to make contact reseating them usually solves the color bvleed. other than that you are using the wrong driver
Jun 20, 2009 | SAMTRON 55V 15" CRT Monitor
HCL 17" monitor display problem
Hi there ,
It seems that you have a vertical section problem ,It might be possible some capacitor might have gone wrong
Jan 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Colors have gone wrong
There could be 3 reasons for this...
1. If color settings are changed from the computer...
try to reset to defaults
2. if colors are changed from monitor..
try to reset to factory defaults
3. If the Monitor cable is loose..
try differnt monitor if available with the same cable which is used to connect monitor and computer, or try using different cable on same monitor and computer.....
Nov 02, 2008 | Dell E176FP 17" LCD Monitor
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Proview InnoVision VM541 (White) 15 in. Flat Panel LCD Monitor Logo
1,414 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Bastian Farkash
Bastian Farkash
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
