Question about Sony STR-DE315 Receiver
Sony STR-DE315 will not power up
It has no standby light have checked the standby transformer and it has 12vac going to the standby board but that is as far as I can go will not turn on
  • 10,594 Answers
Do you have its service manual to go further in unit? let me know as schematic is necessary to rectify its problem of no power.
Regards,
Posted on Sep 10, 2008
  • Shahid Electronics
    Shahid Electronics Sep 10, 2008
    please check Q951 volts at collector 12.5v and 5.6 at emitter. if 5.6 volts is blocked, system control IC is not being powered to function. check IC950 if Q951 has no output.
    Let me know results to proceed further.
I have a sony kv-2199xf TV .. this TV no power on ..not working standby red light .. ac power board working fin.. i replaced STR but no power on and standby light no working.. how fix this prob?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 30, 2015 | Sony Televison & Video
My Sony receiver amplifier model number Str-de315 has just stopped working clicks on 2 lights come on but nothing else k
no front panel display means one of twot hings: either the power transformer is blown, or the main power fuse. If the main power fuse is blown, then there are likely to be shorted output transistors that will need to be replaced.
May 03, 2014 | Audio Players & Recorders
Sony STR-DE575 connected to 220V
Doubt the main pcb needs replacing, but the standby transformer would definitely go in that situation. Standby transformer wouldn't be that expensive, but no way to say that it's the only thing that is bad. It is also soldered in, so you would need to know how to do that to replace it, or bring it to someone who could. If you're staying long-term in Europe, it might just be better to buy something local so as to not run into this problem again.
Apr 19, 2013 | Sony Str-De575 Stereo Receivers
My Sony Receiver Model No STR- DE315 Stuck on standby soon as switches on ,Anyway can assist...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 31, 2011 | Sony STR-DE315 Receiver
Worked perfecutly but wont power up after a power outage. What do you think is wrong. Bass bost and hall lights come on.
The power supply is bad. Check for open fuses. If fuses are good, then the voltage regulator in the power supply may have damaged.
Nov 23, 2010 | Sony STR-DE315 Receiver
If the reciever gets real hot would that cause it to go in protect mode? Sony str-de315
It could! Most of the newer receivers these days need alot of ventaltion!
Unless its being played to loud with to many speakers connected!
Apr 13, 2010 | Sony STR-DE315 Receiver
STR de315 shows 'protection' after 10 minutes. Is this a common issue?
Does it still do this if the speaker wires are disconnected? The amp is protecting itself from a short on the output. maybe yo have a dead or distorted driver in one of the speakers. Also there could be a defect in on of the amp circuits.
Mar 25, 2010 | Sony STR-DE315 Receiver
Sony STR- DE315 Transformer Voltages
yes primary smoothing capacitors it place just after the rectifires.
Jan 08, 2009 | Audio Players & Recorders
Where is the "woofer"?
its on your front speakers there suposed to be a towers
Dec 24, 2008 | Sony STR-DE315 Receiver
Power fault
You probably have shorted rectifiers and/or transistor(s) on standby board. Trouble-shoot rect bridge and cap. Feel stand by circuit transformer for abnormal heat, sure sign
Mar 12, 2007 | Sony STR-DE545 Receiver
387 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
