Question about Cosco Alpha Omega Elite - Hammer Print
Removing carseat the seat is attached to the car's "latches" and i can't loosen the tethers to remove the seat. please help
If you mean that you can't get the hooks off the metal latches in the car then simply push the top of the baby seat to the top of the seat in the car that should give you some slack. I had to do it this morning when I went to turn my sons seat around. Also when you undo the hooks turn them sideways to make sure they just dont rehook.
Posted on Nov 19, 2008
Cannot fold down my rear seat to access the child seat anchors. is there any way to release the rear seat from the boot?
Child Seat Restraints - FSB Forums - FullSizeBronco.com
www.fullsizebronco.com/forum/23.../182333-child-seat-restraints.html
Sep 22, 2010 - My rear seat hasnt been mounted in 6 years and my son Wyatt has ....Join Date: Oct 2006 .... Tether Strap Anchor Attachment for the Second Row Center Seating ... With the rear seat folded forward, remove the bolt retaining the rear ..... If you can't track down the part, send me a PM and I will get my Ford ...
Solution for car seat anchor tether - Tundra Solutions
www.tundrasolutions.com/.../119126-solution-for-car-seat-anchor-tether/
Dec 11, 2007 - I have a 2004 Tundra and I just installed a forward facing convertible carseat. It's almost impossible to get the tether strap attached to the ...
Child Car Seat Fitment in Trucks ' IH8MUD Forum
Dec 02, 2015 | 2006 Rover 75 Connoiseur
How do I install an infant carseat in the 2004 mazda mpv
Is it a LATCH type seat? The best location is the middle row. There is an anchor in the rear bottom where you can clip the tether. The rest of the seat is secured by threading the warbler through the rear of the child seat.
Oct 02, 2014 | 2004 Mazda MPV
Bought used Britax Marathon and Roundabout carseats, without the manaul. Need directions on how to install- rear facing for now, but will need directions on forward facing as well.
Go to the Britax website they have a pretty detailed explaination. Basically use the latch clips put your knee in it and pull tight. where you get the real security is though the tether that comes of the back of the headrest, you attach that to the floor clip in your car or under the front seat if you dont have one.
Nov 05, 2009 | Britax Marathon
LATCH Attached?
The latch can be used in the rear facing position.
On mine there was a screw which secured the nylon to the seat.
You need to remove the screw and remove the LATCH belt.
The LATCH belt must then be threaded through the belt location under the child's seat, rather than behind.
Pay attention if there are any arrows on your LATCH belt which point up, so that you thread the belt the right way. Remember that the seat is going to be rear facing! : )
On the side of my seat it shows a picture with the LATCH in use, threaded underneath the child's seat. Maybe your shows this too.
Hope this works for you!
Stuart
Nov 21, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Uninstall snugride base
The straps should have a release buckle, just pull it really hard while the carseat is removed. Its a lot easier if you put all your weight on the base like kneeling down on it while pushing the release buckle toward the crease of the seat and alternating weight on the base. Good Luck, and remember, you can always cut and replace the belt if necessary!!:)
Aug 30, 2008 | Graco SnugRide - Giselle Infant Car Seat
Safe Seat stuck to base
Ok. You should be able to put your weight on the base to create some slack in the strap. Then push the release buckle and alternate your weight to pull the strap and loosen. Then you'll have enough room to manipulate the improperly installed latch.
Aug 25, 2008 | Baby Gear
Can't figure out how to attach the tether strap to my car seat. It's an Evenflo Traditions
you have to tuck the loop in through the back of the car seat from the bottom to the top and then tuck the length of the tether through the sewn loop in the tether strap. I found it helpful to have a firm, flat surface (like a butter knife or a ruler) to help guide the tether along the molded foam that is not removeable. Plan it out in advance so the hook is the right way up when you are done, to save yourself some grief.
Jul 02, 2008 | Evenflo Chase Comfort Touch
Global Car Seat attachment bar
I do, but I usually don't use it. My Graco carseat latches into the cushion bar w/o a problem
May 07, 2008 | Maclaren Global Buggy Atlantic Umbrella...
Installation of Car Seat base
Try this link it seems very good http://www.aap.org/family/carseatguide.htm
May 13, 2007 | Cosco Travel Systems 01-938 Stroller
Cosco Alpha Omega Elite - Hammer Print Logo
73 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
