Hello im Leo,my zoom mrs 1608 multitrack is not working properly.When i turn it on it checks hdd then says ver 1.0 and then proceeds to do nothing else;( iv tried leaving it on 4 a while but all that happens is after a minute or two all the LED lights for the input knobsat the top come on...then go off and it just stays frozen on ver 1.0.And whats worse is the on off button only works for turning it on! i have to turn off at the mains?? i would be very grateful 4 any help u guys could give me.cheers
  • velmonte25 Sep 29, 2008
    same exact problem
  • Anonymous May 19, 2009
    I have a similar problem, I turn on the power and the LED screen just blinks and sometimes the indicator ligths above the Gain knobs light, but it won't do anything else.
  • 12 Answers
SOURCE: this yamaha receiver goes on for 1 second then off.
This is the protection circuitry. Mine is doing the same thing. I'm trying to get a schematic for it right now ;-)
Jon
Posted on Feb 04, 2008
SOURCE: Casio ex-s600 frozen
I just took the battery out and then put it back in.
hehehehe
Posted on Mar 06, 2008
  • 4234 Answers
SOURCE: Yamaha RX V490 Turning itself Off
The amp is in protect mode which means that the output section has a problem. With nothing connected, there are defective parts inside the unit. This type of problem is not likely to have been caused by any shipping damage. I would guess that the output transistors are shorted.
Dan
Posted on Jul 22, 2008
  • 3 Answers
SOURCE: denon avr 887 input problem
Sell it on Ebay and buy a new 2309.
Posted on Jul 29, 2008
ngfam1
  • 639 Answers
SOURCE: Works, but goes into protect when you turn up/down volume
If its new call Sony and get service????????????
Posted on Aug 28, 2008
Zoom MRS 1608 will not power on
I suggest checking to make sure those 2 units can actually use the same adapter and also check the polarity on both to see if they are the same. Most stompbox stuff usually has negative on the center of the socket, instead of positive like other devices. If I spend a little time I could find the manuals and find out for myself but, this was my logical "top of my mind" kind of advice. Those values (volts,mA, and polarity) must be known in order to help you further. I believe it will be 9v, a few 100 mA's, and negative in the center on both but, not sure.
Mar 21, 2014 | Music
Tascam 2488 digital portastudio
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
Mar 08, 2008 | Tascam 2488 Portastudio Multitrack...
How can i unlock my mrs zoom recorder 1608 as it wont let me into my tracks i have stored
Here is the manual for that unit, I didn't see anything in there about that except saving and opening files or samples. Hope this helps you.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CD0QFjAB&url=http%3A%2F%2Fwww.zoom.co.jp%2Fdownload%2FE_MRS1608.pdf&ei=lbE_UZj2G5SK9ATKhoDIBg&usg=AFQjCNEfNb_7T9tO_5VYIriVUkG6PyfgWA
Mar 12, 2013 | Music
I HAVE A ZOOM MRS-802 B. IT will not start up. keeps reading HDD eror. Can not scan disc due to this reading pops up after step 1 of BASIC MAintenance Procedure. Does not go to ExtFunc pops back to...
Mine did the same thing. Just by chance we had a universal laptop power supply unit with interchangeable tips made by powertran & my wife said to give it a try. The unit has a display window on it & it reads 16.9 volts when the zoom is running. When I plugged it in I couldn't believe it was going through it's start up menu. On the package it says 15 - 20 volts DC 90 watts & I reckoned it shocked the zoom into working again...well anyway, it worked & the zoom is running again. The power box package cost $89AU that I got at an electronics store.
Jan 30, 2011 | Zoom Music
I cant figure out how to burn my songs onto the cd writer of my boss MRS-1608 multitrack I've lost my manual and any help would be really appreciated! thanks, Jon
Here is the link:http://www.zzounds.com/item--ZOMMRS1608 scroll down, click on docs, click on user manual and there you go for free. Let me know if this helps.
Nov 30, 2009 | Music
My zoom multitrack says "check disk"
http://www.zoom.co.jp/archive/English_Manual/E_MRS1044v2.pdf If this is the model you have you have to format the hard disk before using it the first time. You may also have to restore the machine to factory settings using the recovery disk that came with it. The link is to the download for the manual.
Aug 07, 2009 | Music
Freezing while booting up - Zoom 1608 - PLEASE HELP!!!
Try the procedure on page 184 of the owners manual. Heres the link:http://www.zoom.co.jp/archive/English_Manual/E_MRS1608.pdf If it won't completely download keep hitting refresh. I had the same problem downloading. the InitFac will restore the system files but will supposedly not affect user created data. In any case read the whole thing carefully. I don;\'t have one but I downloaded the manual to try and help. Let me know how you make out.
Jul 30, 2009 | Music
2488 will not boot up, says not reading the hdd check the h/w .
Usually this is a problem with the Hard Drive not getting enough power to spin up properly. The AC power adapter is the usual suspect.
bd.
Oct 21, 2008 | Tascam 2488 Portastudio Multitrack...
Hi, I have a problem. I have an MRS-8 and I was recording and wanted to do a new Project so I selected new Project003 (the other project was Project002) now I cant retrieve the old project. how can I go...
Here are the instruction to retrieve a previously saved project on the Zoom MRS-8.
1. From the main screen press the [SYSTEM/UTILITY] key in the display section.
2. Verify that "SYSTEM PROJECT" is shown and the press the [ENETR] key.
3. Use the LEFT and RIGHT cursor keys to select the operation you want (look for PROJECT SELECT).
4. Press the [ENTER] key when it says project select on the display.
5. You'll see the name of a project in the following format "PRJ002".
6. Turn the dial to select the desired project.
7. Press the [ENTER] key to load the project.
8. When loading completes the unit will return to the main screen.
Cheers,
bd.
Sep 08, 2008 | Tascam 2488 Portastudio Multitrack...
Monitor will not start up!!
It may be a corrupt backup you are trying to install, but if there is a corrupt file you will need to borrow a genuine XP disc off a friend to repair it. You can use your own license number for the copy so your friend shouldnt be concerned with piracy. You may get the pc running by locating on the motherboard either the 3 pin JBAT1 terminal and put jumper from pins 1-2 to pins 2-3 then back to 1-2, or short both pins if you have a 'CLRCMOS', 'CLRRTC' or 'RTC' 2 pin terminals with a jumper cap. Restart pc and it should make you press F1 to set the cmos time and date and hopefully boot into windows, but if not the first paragraph will be the solution to the problem.
Apr 25, 2007 | Acer Aspire T310 PC Desktop
147 people viewed this question
 Grubhead
Grubhead
