there are faint lines in my picture and I was told that it was probably the signal board. I been unable to find a signal board on line. the tv is working but the lines are annoying. I have a samsung hcn653w 65in. rear projection tv. Is this something that I have to have a repairman come out and do? I had one come out but he didnt look all that trustworthy. Or maybe I should get a second opinion. He quoted me nearly 600 dollars. And that he would have to take my signal board apart and send it to Chicago to get re-built. This will take around 4 to 6 weeks. Please let me know if this is correct. Thank you
You weren't very specific about your problem, but assuming you've tried different inputs and tried messing with the convergence setting, it may indeed be the signal board, and you may need to have it replaced. BTW these sets also have an issue with the dynamic focus circuit and with crt fluid leakage. Make sure that you do not have a fluid on one of the crt boards. And as always with repairmen, a second opinion couldn't hurt.
Is it possible to remove the top section from the bottom section in order to move the television...
(More)
Is it possible to remove the top section from the bottom section in order to move the television around narrow stairwells?
I have a samsung hcl473w projection tv. It work fine until I moved it on my truck. It will not turn...
(More)
I have a samsung hcl473w projection tv. It work fine until I moved it on my truck. It will not turn now and only the red light by power button comes on. do you think I damage something from the move.
