Question about GE 30" Self-Cleaning Freestanding Electric Convection Range - Stainless-Steel
Crooked elements Left front element under glass cooktop appers tilted badly, is this normal. this is a new range.
  • 1,543 Answers
No that is not normal. Call for warranty service.
Posted on Sep 10, 2008
Model #jb700tok3 how to lift the stove top. heat warning lite will not go off
Hello. REMOVE POWER FROM THE RANGE NOW! Using a headlamp or flashlight, open the range door and look underneath the cooktop at the front. (The door covers the screws when its closed) There should be 3-4 screws depending on the model, usually black, that have to be removed. The cooktop will now lift up from the front. It is hinged(open hinges so be careful because the glass cooktop can be easily dislodged off the hinged area) underneath the control panel on the left and right sides. The elements will be mounted to the bottom of the glass. You will need to identify the defective element temperature sensor using a voltage/ohm meter. Element designation 56, LR and RR, part number WB30T10129, 6-inch size. Element designation 57, LF, 9-inch dual, part number WB30T10133. Element designation 58, RF, 12 inch, part number WB30T10130. If you are going to attempt the repair, take pictures of the wiring AND clips for each element before you start. Mark the new element with an arrow or dot, etc. with the mounting clip location numbers from the old element( see the numbers for each of the positioning holes around the rim. BE EXTREMELY CAREFUL NOT TO TOUCH THE HEATING FOILS AT ALL--THEY ARE VERY DELICATE! Have a friend/helper hold the cooktop up while you work--this will make the job much easier. I hope I helped you!
Aug 10, 2015 | GE Kitchen Ranges
Replacing the ceran glass maintop
Actually if you've removed the 2 or 3 screws at the front (underside) of the cooktop, you can lift up the front. Prop it up with a board, and then remove the 4 screws that hold the 2 brackets that hold the 4 elements to the cooktop. Now pull the cooktop forward a bit, and you should see a green ground wire attached to the back of the cooktop. If not, then don't worry about it! Just pull that cooktop up and off the range. You will need to transfer the 2 tabs in the back of the cooktop, and the silver steel bar located at the front of the top to the new cooktop. Then reverse the process to install the new cooktop and re-fasten the elements to it.
Apr 22, 2014 | Kenmore Microwave Ovens
I want to lift the cook top on GE range jbp82shss so that I can clean out all the dust. can I do this
Yes. Disconnect power to range. Open oven door and remove hex head screws at front edge of cooktop from the bottom side. Lift up front of cooktop. Burner units can then be removed from the underside of the cooktop. Be careful not to damage the gray insulating material around the burner elements if you remove the elements from the cooktop glass.
Mar 05, 2011 | GE JBP82SHSS Electric Kitchen Range
We have a CCE3401 Jenn-Aire Ceramic Cooktop. I was making jelly this week when I had a bad boil over. We used recommended products to clean up. It has left a black smooth spot above front left range...
Sorry to read about your problem, I hope this helps you out.
try using an oven cleaner spray... let the range heat up a little..then spray oven cleaner
a new glass top will cost over $600.00 just for the glass.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
Dec 15, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
How do I replace a burner control on a Whirlpool glass cooktop model GJD3044RB00? I know the control is bad, because the shaft came out of the control [left front]
Turn off circuit breaker to range. Remove the cooktop from the cabinet and tilt it to give access to the control. Remove the nut on the top holding the control in. Diagram wire connections, disconnect wires, install new control, connect wires to new control, put cooktop back into cabinet.
May need to prop up cooktop in tilt position to keep it in place while you work on it.
If you have trouble/question, let me know.
Sep 30, 2009 | Whirlpool Kitchen Ranges
Front side heat element with ring wont light on ( or heat up)
These type of elements are often known as dual elements. They usually have two separate coils. More than likely the center coil has failed. They cannot be repaired and, in the case with your range, cannot be replaced separately. You will need to replace the entire element. carries parts for your range. Just type in your model number and locate item numbers 5301 and 5302 under the "Cooktop" heading. I do not know which front element your are talking about, but there is a price difference. No, thay aren't interchangeable. They have different wattage ratings. You will need to determine which one it is that you're having problems with. Replacing a single element is not difficult. It can be accomplished easily by following these instructions:
1. Unplug the range before servicing. Even with the unit turned off, there are potentially dangerous voltages present on the wiring harness.
2. Open the oven door and locate the two screws that hold the cooktop in place under the front edge. CAUTION: Do not put any weight on the oven door. You can cause damage to the door springs. Once you remove the screws to the cooktop, close the oven door.
3. With the screws removed, the cooktop will lift up.
4. Use something to prop up the cooktop, or a second person to assist, and carefully remove the mounting bracket to the two front elements. They are assembled together on the same bracket piece.
5. Gently lay the entire assembly on top of the oven box, leaving the cooktop propped up. Disconnect the wires to the affected element and unscrew the mounting clips. NOTE: There are numbered mounting holes on the element, pay attention to which numbers the clips are screwed into.
6. Remove old element. Install mounting clips to new element and reconnect wires. Install new element in mounting bracket and carefully lift back into place on the cooktop and install. NOTE: Use caution when handling the elements, they are extremely fragile. DO NOT touch the ceramic material, or electric coils with your bare hands. Oil transfer form your hands can cause potential hot spots, leading to premature failure of the element.
7. Lower cooktop and secure back in place.
The repair procedures are pretty straight forward. If you have any questions, please let me know. I hope this helps you.
Aug 18, 2008 | LG LRE30451ST Electric Kitchen Range
Replacing smooth top
Have you purchased a new top yet? If you haven't, you can find it at for about $270.00 (item #703866). Just type in your model number in the search index and you will find a pictorial part index for your range. The part isn't cheap, but it would potentially cost you twice as much to have a repair service replace it for you. If you still wish to pursue this repair, follow these simple instructions:
1. First of all, UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. Secondly, is the glass top still intact? I know it is broken, but is the glass completely busted apart, or is the top just cracked? If it busted, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cooktop. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4. On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the cooktop and leave the elements in place. Place the whole assembly face down on a soft surface (like some old towels, or a blanket) and remove the surface element assembly leaving all the elements wired together. Place the new cooktop face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place. Install the new cooktop back on the range and you are DONE.
5. If the wiring harness does NOT unplug, there are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
5. Lay the intact element assembly, with wires still connected, on top of the oven box handling the elements with care. they are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of.
7. Use care when screwing into the new cooktop. CAUTION: The scew holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
Good luck and I hope this helps.
Feb 11, 2008 | Maytag MER5770 Electric Kitchen Range
Ge Spectra Electric Range Cooktop
I'd say its not a normal event, and that the element is about to burn out. I just replaced mine and on the old element there was a nice burn mark where once the element was solid.
Oct 28, 2007 | GE Kitchen Ranges
One of my burners is out, and I do not know how to get under the cooktop
You can check the element from the switch on the control panel. Unplug the oven, remove the back and put an ohm meter on r1 and r2 terminals to check resistance. If it shows open then the element is bad. If it shows resistance then replace the switch. To remove the top there should be screws under the front part of the top which you can see when you lower the door then just lift up. You won't be removing just the glass.
Sep 23, 2007 | Frigidaire FEF365AS Electric Kitchen Range
Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Aug 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
GE 30" Self-Cleaning Freestanding Electric Convection Range - Stainless-Steel Logo
111 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
