On/off switch on tv doesn't work - Goodmans Tv 42" model SAM42V3
  • 111 Answers
SOURCE: no sound
Have you checked that the TV isnt Muted/ Volume turned to 0 ? i would check in the menus if that is the case.
If this is not what is happening i suggest you surf over to the Goodmans website at www.goodmans.co.uk/ to see if there is any troubleshooting/FAQs on there. if not, i would call Goodmans customer Support, their number is located on the said website !
Hope This Helps !?
Posted on Oct 27, 2008
farr64
  • 121 Answers
SOURCE: goodmans 42" plasma tv Model NR GTV42P4
not sure i can solve this but you could try tapping the bottom of the set's case or back cover to see if its dry jointed. as you said both speakers are working so the fault lies with one of the outputs of the sets amp.if you have a headphone socket check to see if both channel's work . dry joints are quite common. also have had this problem and it turned out to be a faulty scart lead always check the obvious first good luck ..colin
Posted on Apr 27, 2009
  • 3 Answers
SOURCE: popping sound then tv went dead goodmans
A lot of tv's do that when it overheats and makes a poping sound. check your fuse or call a professional to take a look
Posted on Jul 05, 2009
SOURCE: the receiver doesn´t work. When i switch on,
Hi. Check MP40 in PIP Box.
Posted on Sep 24, 2009
  • 718 Answers
SOURCE: Please, Searching the replacement for
You can go to;
http://www.1sourcecomponents.com/search/search.htm
and enter the part number.
> Get the data sheet for the item if it is not the original manufacturer.
> Make sure the pin out on the replacement can be used in your application. Sometime they change them.
> Make sure the packaging can be used in your application.
Posted on Mar 08, 2011
We have a LD3266D Goodmans TV, since the switch over we have to tune the TV in everytime it's switched on, before the switch over the TV would auto tune and store the program's with no problem, any...
If you switch your tv of at the plug the software cant do the updates. Leave the tv in standby over night and that should work.
If you do leave it on standby but still losing channels contact goodmans as you may need an update of the software
Oct 28, 2011 | Goodmans 255NS 25" TV
My goodmans tv switched itself off and won't work
Make sure that the electricity is working
Make sure that every connection is in place the
scart connection as well.
Disconnect and wait for 2-5 minutes
and connect and start.
If that does not work look for troubleshooing in the manual or click on the name of your TV here at the top of the page.
good luck
kolbrun
Aug 11, 2011 | Goodmans GTVL32W27HDF 32 in. LCD TV
Goodmans 42" LD4 255 HD.\r\nlost remote and using
Yes,ur tv does require a tv orginal remote will help u to used,but the child lock mode must have a secret codes to enter it.Can't turn tv on,must have the tv original remote to enter child lock secret codes though.Tries Goodmans website look for there 1-800.. call ask their customer service they can help to erase the child lock secrect password,if u don't know it.Try website Remotes.com to buy the tv original remote.
Jul 18, 2011 | Televison & Video
Switch TV on then a blank red screen appear then a green and then a blue which then just repeats that sequence of colours every second. The remote control packed up working some month before. - 2 year old...
turn TV on, let the Tv cycle through the three colours, then using the remote press the menu button followed by the standby button. press standby button again and it all comes up working.
andy
Sep 20, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Hi my plasma tv doesn`t switch on?
could b flyback transformer, hard to tell with out benc testing , no power is cheaper to fix than picture problems and normally a lot less God Bless
Apr 15, 2010 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Can't find the manual for my Goodmans TV. I need to re-tune can you help? It is model number LV1570FVT.
Goodmans doesn't list that TV. Please review this link and check the model number again.
http://www.goodmans.co.uk/productlist.aspx?cid=BLCDTV&language=en-GB
Here are all available user guides for Goocman TVs:
http://www.goodmans.co.uk/supportcategory.aspx?cid=UGTV&pcid=UserGuides&language=en-GB
If you don't see your TV model, select one that is "close" and see if the manual helps you re-tune your TV. They probably all re-tune the same way.
Sep 30, 2009 | Televison & Video
No sound
Hope This Helps !?
Oct 27, 2008 | Televison & Video
Goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Dec 30, 2007 | NEC PlasmaSync 42MP3 42 in. Television
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
