Question about Moultrie MFH-DGS-200 Digital Camera
Moultrie game cam
The camera has only been out for about 10 days got about 20 pictures of it after 5 days and it worked just fine. But when I went back to check the camera it would take a picture but it would not save it. The camera would only say 00/100 instead of 01/100 when it took a pic. It is like it wont save thee picture and when i tested it it said error 400 what can i do?
  • Anonymous Sep 15, 2008
    Same problem here and I can't reset erase the images as it says REDO but won't erase images on memory card.
  • Anonymous Nov 29, 2008
    exact same problem
SOURCE: moultrie game camera won't flash
we get beutiful day pics, but totally black pics at night
Posted on Aug 23, 2009
  • 296 Answers
SOURCE: Moultrie i60 game cam takes pics constantly while
If within warranty, with valid receipt.....send to Moultrie
Posted on Feb 19, 2010
  • 296 Answers
SOURCE: user manual needed for a moultrie mfd-cdc model
here's your manual:
http://images.ebsco.com/pob/Moultrie/catalog/GameSpy100V2Manual.pdf
Posted on Feb 20, 2010
  • 296 Answers
SOURCE: Moultrie I450 Game Spy
Before installing a sd card, internal memory MUST be erased. From setup,use the up/down buttons near the select button until the display reads "ERASE ALL PICS(MEMORY)? NO" toggle up or down button to get"YES", press the select button and wait until until it says "DONE".
Go to setup screen, power off, intall sd card...should be good to go.
Posted on Mar 06, 2010
  • 296 Answers
SOURCE: how do I get software to view my pics on my
PLUG CAM TO PC ...TURN ON CAM found new hardward wiz comes up choose pick driver from list, choose generic on left/imaging device on right;find new drive under"my computer"double click folders and sub-folders until pics show up...enjoy
Ron L
Posted on Mar 14, 2010
How do you get the m100 to take pictures by motion only?
Search Results
    [PDF]Instructions for M100 GameSpy Digital Camera - TrailCamPro
    www.trailcampro.com/manuals/2012/m-100.pdf
    THANK YOU for your purchase of the M100 GameSpy Digital Camera. Please ... The Mode Button selects the 3 modes of the camera - Camera Setup Photo Review or ...Accepts the Moultrie PowerPanel accessory (sold separately) only. ... Camera operates in Plot Cam mode during the day and Trail Cam Mode during.
    Moultrie Game Spy M-100 IR Mini 6.0 Megapixel Digital ...
    www.walmart.com/ip/Moultrie-Game-Spy-M-100/16386230
    Walmart
    Rating: 4.5 - ‎21 votes
    MOULTRIE Game Spy M-880 Low Glow Infrared Digital Mini Trail Game Camera ' 8 ....You can easily hold this mini IR camera in your palm. ... MFH-DGS-M100 .... Will ittake pictures only on motion detection? ... can get any size you want but don't forgetyou will have a lot of photos to delete. ... A. Will do video clips and stills.
Dec 25, 2015 | Moultrie Game Spy M100 Game Camera
I have a Moultrie A5 Game Camera it will only take pictures for 1 day then I have to reset the camera before I can get anymore pictures am I setting it up wrong
Yeah, mine is doing the same thing
i think. I haven't left it out for a day, just been trying to get it to work. It's taking one picture when I turn it on then looks like it goes to sleep and even when I try to wake it up it just goes back to sleep 5 seconds later. I found an option in setup that says 1d but I think I read in the instruction guide that it was just to label which camera number it is so that when you plug in the card you know which camera took it.
May 13, 2014 | Moultrie A-5 Game Camera
Resetting the Moultrie A-5 Game Camera
HARD RESET TAKE OUT BATTERIES SD CARD PUSH THE ON OFF BUTTON FOR ABOUT 5 SECONDS LEFT EVERYTHING OUT FOR 2-5 MINUTES. THEN PUT THE BATTERY BACK IN TURN THE CAMERA ON IT SHOULD SAY NO CARD. THEN TURN IT OFF THEN PUT THE SD CARD BACK AND TRY IT IN THE DARK AREA TO SEE IF THE FLASH WILL GO OFF. IF THAT DOESN'T WORK WILL NEED TO SEND IT IN FOR REPAIRS.
Nov 07, 2013 | Moultrie A-5 Game Camera
I have a moultrie cam viewer. It views pics off sd cards for my moultrie game cams. (I have 2 cams both with 16g sd cards in them m-80 xt, m-80 blk) it has worked fine for about 7 months. But now it just...
Try the cards in another camera. If you get good images to show, then the problem is in the cameras. If not, then the problem is in the reader. See whether some dirt is in the slot interfering with the contacts.
Oct 19, 2013 | Cameras
Moultrie D50 game trail camera won't take pictures in dark
Does the flash work? Could be flash circuit or day/night sensor.If you have another D40/D50 camera that flash works but has other problems,swap out the sensors.If not the sensor but the flash circuit then most likely one of the large charge capacitors which has to be soldered in.I use a digital multimeter with I/O capacitor test function..these caps should be about 250mfd.
Nov 21, 2011 | Moultrie MFHDGSD50 Game Spy Camera D50
How to change the timing of pictures on the moultrie to not catch everything but deer.
In the setup, it has a function to delay time between pics...1 min. works best for game trails; 5 min. for feeders, ect. However, these cams are sensitive; blades of grass; a bird flying by; the tree it's mounted to swaying; heavy rain...should I continue?
Nov 08, 2009 | Moultrie MFH-DGS-100 Digital Camera
Moultrie DGS160 Game Camera Error 20000
Forget calling Moultrie...I think their answering system is permantly set for "off-hour" times...you may have to e-mail them several times be fore (after4-5 days they get back to you.
You're error should read error"0200000"...flash error or flash charging...getting this during system diagnosis probably is that you failed to cover sensor during ck.
I f this is a constant error...turn cam on; remove batteries; turn system off; insert batteries and try again. .
Oct 03, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Flash will not "fire".
The camera has a "motion detector". And is generally for taking pictures automatically whenever a "subject", such as wild game, come within the detector.
That flash is for taking pictures of subjects less than 12 ft away and not a darkened area beyond 12 ft.
If you are using it to automatically capture in the evening, then point the camera lower, like to the ground 12 ~ 20 feet away. It will shoot some nice, but somewhat grainy pictures!
If you are holding the camera to take pictures, it wasn't designed for that, but it will work for "close" shots.
Sep 25, 2009 | Moultrie MFH-DGS-200 Digital Camera
Moultrie MFH-DGS-200 Digital Camera Logo
101 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Steve
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
