Question about Philips 30PW633R 32" TV
Phillips match111line hd
When i turn on tv i can h ear it crstal clear but there is no picture,tried adjusting the settings and you can see the picture very
3 Suggested Answers
  • 48 Answers
SOURCE: sound but no picture
I ran into this problem before and I can tell you what parts to check/replace - if you know how to do that. Since it took me hours of troubleshooting time, I would expect to be compensated a small cash fee for this info, but I don't know how this works on this site.
Posted on Jan 28, 2008
  • 147 Answers
SOURCE: phillips 52" tv
It might be simply a matter of having someone adjust the magnetic rings on the yoke of your picture tube to refocus it - a lost art.
A 15 minute job for a seasoned veteran, perhaps, but expect to pay a minimum charge of 1 hour's labour, at $85-90 CDN.
Posted on Sep 18, 2008
Toshiba theaterwide hd
replace the lamp on your TV, but only replace it with PHILLIPS brand. Anything other than that, will not last. We just replaced ours with Phillips and the picture is much brighter. It really shows the HD quality of the tv.
Mar 24, 2014 | Televison & Video
RCA Truflat tv picture quality is diminished, it is like the brightness is too low, but that is not the problem. We can turn the tv off and on and sometimes the clear picture will appear again
CRT sets use a special transformer called 'flyback.' This device has two, sometimes three adjustments on the transformer, one of these is a focus adjustment. All of these controls are variable resistors and these can develop internal contact problems at the 'wiper.' This problem can often be solved with some success by turning the control back and forth several (many) times to clean the contact area inside.
This is an area of high voltage but the adjustments are insulated so stray fingers may get a surprise so be careful if you try the following- - Pull AC plug from wall. - Remove the back cover; 6-8 screws, may be hex head or Phillips - In good light, look for a round peg-like control on a larger black device with a top cable running toward the side of the picture tube, with 'Focus' molded next to it or around it. - MARK the current position (correction fluid works well) - If you can identify the right control, turn it back and forth several times; most of these can be turned with a flat blade or a Phillips screwdriver. - Return it to its original position.
If the power cord can be separated and plugged into the set, turn it on and observe the picture; it may be worse than before but don't panic, you did move it. Best case is to have a mirror so you can watch the screen while not poking your screwdriver in the wrong place. This (focus) is not a potentially damaging adjustment, the other one (or two) can be since they may act on the high voltage level, focus does not. Adjust for the sharpest picture.
There are other defects which could cause this problem but the above is the most common and the others require technical background and a couple of pieces of test equipment.
If this resolves the problem, you may get many more years from your set instead of going 'flat/big screen' and being really ********** when it fails in a year or two.
Aug 24, 2010 | RCA TruFlat 27F520T 27" TV
How to adjust picture setting on 23 inch samsung tv cant get to advanced settings .have direct tv no hd but the picture is not very clear at all.thanx
Samsung LCD P2370HD 230?N when I turn on the channel is switched on after a few seconds the LCD screen is black and none of the menus do not work and the state remains a solution to this problem is?
Aug 08, 2010 | Samsung P2370HD 23 in. TV
Recently purchased a Sony Bravia KDL37EX403 1080p 100HZ flat screen tv. The picture seems to be poorly defined, almost pixelated around the edges of figures and letters - sport is almost unwatchable with...
Your old TV was most likely a SD (Standard Definition) TV. SD signals look better on SD TV sets than they do on HD TV sets. This is normal. If you will, imagine having a tiny wallet photo reprinted as an 8"x10" photo. The image would be grainy and not have the crispness of the original. This is the same principle. Your SD source is being blown up to fill an HD screen. Once you add HD to your programming, the old TV will be forgotten. I hope this was helpful.
Jun 12, 2010 | Televison & Video
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
Cannot get my HDMI cable linked from my ps3 2 my hd tv
Try video settings on the playstation 3. Adjust it to reflect hdmi.
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
No sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Dec 03, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
How do I get HD broadcasts on a Phillips 60PP9352 TV that's 'HD ready'?
Im guessing your in the UK.
Asking about HD as you havent stated what country you are in.
Ok You will need the following to be able to watch HD pictures on your tv set.
Either Sky HD which involves having a dish fitted. Or Virgin cable system which is not available all over the country.
If you go to either of these systems you will need to pay a subscription to view the HD channels.
Jan 01, 2008 | Televison & Video
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 30PW633R 32" TV Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
