Has it been moved latley? is there any auto align mode? i know the lenses can bounce inside there during a move and it can throw off the focus. If there is no kind of auto align it may need serviced. Usualy they have to come out and realign it using special tools. The tools display a cross on the screen in each color and they adjust the throw of the guns that refocus all the colors to the center till it becomes one solid color.
The panel drops down from the fron and you adjust the pots with a plastic tool that realigns the guns. There may be a mode in the settings to display the image you use for the alignment. This is a common thing and i think they recomend it be setup at the home and not moved after its setup.
Was this helpful?
Yes
No
Solution #3
posted on Mar 18, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hi, i have the same problem and my tv service told me nothing was wrong
Solution #4
posted on Mar 04, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Fault is convergence needs attention can be ajusted via remote control, if will not ajust then component failed on main PCB, need circuit diagram to locate faulty part and understanding of electronics.
the guy was just out at my house and made the tv display a white line graph and brought all the colors to one spot then tried to save it and it wouldnt he said the parts arent aval and it would cost a mint to rebuild. how did he get the graph up
When my husband turns the television on, it will come on but after about 1 min it goes off by...
(More)
When my husband turns the television on, it will come on but after about 1 min it goes off by itself. I don't think there is any accompanying sound or anything, it just goes off.
A friend of mine recently gave me an older floor model RCA model P46823BL 47 inch TV
but the...
(More)
but the problem is the about every 10 minutes or so the channel random
changes to I can fix this
problem it is driving me nuts
picture & sound went off. thought someone turned it off then it started beeping? only stops when...
(More)
picture & sound went off. thought someone turned it off then it started beeping? only stops when i unplug it. ???
