Question about Philips CDR785 3-Disc CD Recorder
Intermitent audio I have a Philips CDR785 cd recorder. The problem I am having is, when I play a cd on the 3 disc changer side, the cd will play music on a average of 30-40 seconds before the sound cuts out for 3-4 seconds. This same situation seems to repeat it-self at the same intervals, maybe playing the music a little longer before the sound cuts out, but the sound seems to always stop between 3-4 seconds. I also want to point out that at the points when the sound stops the disc continues to spin it, it does not stop and in those 3-4 seconds. Any help with this will be greatly appreciated.
  • Gregory Scott Apr 05, 2006
    Hi BrowerR64, I played up to seven different cds and got the same results, all were virtually brand new without any scratches or dirt.
    Novelist:
  • 130 Answers
I had that happen before, one problem was my car had bad shocks or i hit a pothole in the road. The second time i had the volume up so loud the bass wass thumping the floor and it skips the CD. My question is, how lowd is the thign turned up? :P Some CD players load the data into a memory and then it plays from the memory till it needs more info. It maybe that the unit is not stable or the CD is not balanced right so it cant read the info at a consistant speed. The music maybe playing faster then it can read because of the vibrations. Is the disk clean? i know this may sound dumb but it is easy to over look. If the surface of the data side is so scratched up it may have problems reading the data quickly enough. Sometimes the coating can fall of the disk if you hold it in the light you can sometimes see spots threw the disk where the foil has been chipped off. The CD player could have a focus problem also, it could be damaged in shipping or have been dropped and it cant focus properly on the data. Do you have any other disks to try? a new one? one you never play?
Posted on Apr 04, 2006
  • 26 Answers
Can you skip tracks?
If you can and the sound stops it is posible that the tracking alignment it out.
If you can't skip forward, it could be that the pick-up is sticking.
This could be on the guide rail or the gears.
Some times the sledge motor gear splits on the shaft.
I suggest you take it to a service centre.
John w
Posted on Dec 17, 2007
  • 112 Answers
The CDR 785 uses a philips VAM 2202 laser for the playback only side. Sounds like a capacitor in the power line near the DAC on the control PCB of the laser is faulty causing the DAC ( that converts the laser's signal to sound ) to cut out. When you record internally, does the recording work normally with no dropouts? This would prove it, as the signal goes direct to the recorder without going through the playback unit's DAC.
Posted on Dec 08, 2007
  • 112 Answers
Placing good cd-r disc for recording shows "insert
u mabe inserting the wrong disc all phillips cd recorders uses cd-r or cd-rw that says digital audio.
Jul 28, 2011 | Philips CDR785 3-Disc CD Recorder
How do I record from an external source?
Read the manual...
http://www.p4c.philips.com/files/c/
It takes some time to load. Seven CDR785 variants. Find yours.
May 12, 2011 | Philips CDR785 3-Disc CD Recorder
Where can i find and buy a remote for my Phillips cdr785 3 disc player/recorder?
Looking through Phillip's online directory is a possible choice,
However, for a large inventory and generally lower prices, I suggest searching on Amazon or eBay.
Mar 02, 2011 | Philips CDR785 3-Disc CD Recorder
I cant get it to record my records from my sterio to the cd recorder
You might need to fill in something about how your records are being played, on what turntable, through what intervening electronics.
Is the level too low? You may need a PHONO preamp.
Are you using CD AUDIO recordable media? Must say "audio" or "music" on the disc.
Dec 28, 2010 | Philips CDR785 3-Disc CD Recorder
I have this recorder and when I go to burn a cd,
Always 1/3? Try just playing a full CD through it to see if it can smoothly accesss the whole disc in a linear fashion just like a recording would do. Might be something physical if it has problems at the same relative positions recording and playing. Otherwise, ther're really no reason an electronic failure should care where on the disc it fails.
Jan 28, 2010 | Philips CDR785 3-Disc CD Recorder
Not recoring
solution to your delema, your machine will only record onto a digital audio cd.
Jul 16, 2008 | Philips CDR785 3-Disc CD Recorder
Phillips cdr 950 audio cd recorder
Hi Averil
Get yourself a copy of the manual directly from the Philips website (look on the left of the screen for all the relevant links)
Your CD recorder has a 2 pairs of phono (rca) sockets on the back.
Connect your keyboard's output (line out ideally or headphones if there isn't a line-out) to the inputs on the back of your CD recorder. And connect the outputs from the CD recorder to your amplifier. If you don't have an amp, you can plug headphones into the CD recorder so you can hear what you're playing.
Good luck! Let me know how you get on with it.
Jan 10, 2008 | Philips CDR785 3-Disc CD Recorder
Won't record
I've just spoken to a friend who also has one of these older Philips recorders & he has the same problem.
As per my previous post, he fixed his problem by locating old stocks of blanks. New audio discs seem to have been manufactured & optimised for fast writing speeds (up to 32x speed) & this is causing the problem (you can't write at x1 or x2 speed to these new speedy discs).
Trying a few different brands of discs to try out is a whole lot cheaper than a repair. I suggest when you find a brand that works, you stock up on these discs as it seems they will become ever rarer.
Dec 11, 2007 | Philips CDR785 3-Disc CD Recorder
Philips CDR785 3-Disc CD Recorder Logo
405 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
