Scoschehttps://www.scosche.com > media > guides
PDF
PRELIMINARY: Disconnect the negative battery cable. ANTENNA: The factory antenna is located on top of passenger's side front fender. RADIO REMOVAL AND IN-DASH ...
2 pages
Is this the harness you are using....Metra 70-1771 Radio Wiring Harness for Ford/Lincoln/Mazda 1998-Up into Car, 16 Pin https://www.amazon.com/dp/B0002BEWZQ/ref=cm_sw_r_cp_apa_i_HzCTCbPS1C6D7
one of your speakers is blown and shorting out your deck. disconnect one sspeaker at a time and when it starts working fine you know that's the blown one.
missing would show itself at low engine speeds.bad starting.or heavy load (going up steep hills)a miss at high speed would not be felt (normally)without other symptoms(lack of power etc)have you tried using higher octane fuel......mazda rec 92+ octane...
There are two 3/8 inch wide black trim pieces on either side of the radio - look at the sides of the radio and you'll see them. Carefully pry them off and you will see the holes.
