Question about Refrigerators
RE: sweet smell from refrigerator
I've got a sweet smell (that I think of as a gas smell, but it's not really) coming from my 24 year old Amana refrigerator. It's cooling fine so it's not a gas leak and my husband says freon is usually odorless anyway. I've cleaned it 3 times - once with water and Mr. Clean, once with diluted bleach, and once with a mild solution of vinegar and water. I've even left it off and open with a fan running into it. The smell is still there. The pan under the refrig has been scrubbed too. The smell seems to be coming from the vents in the freezer. At least this seems like where the smell is the strongest. But maybe that's just because of the re-circulating cold air. I'm exasperated. Any ideas? It does have any auto ice maker, but that's hooked up to the water main with a filter on it. (filter is clean).
  • DonnaS3 Sep 13, 2008
    Thanks so much for the info. We'll check it out.
  • Anonymous Jan 22, 2009
    my refrigerator smell like raw meat or blood it had a red brownish leak on the back of the fridge i had to scrub with cameo it came off but it still smells.
    Novelist:
  • 171 Answers
Hi Donna53,
I'm Harvey the Master Plumber.
Your question is: You've got a sweet smell (that you think of as a gas smell, but it's not really) coming from your 24 year old Amana refrigerator. It's cooling fine so it's not a gas leak and my husband says freon is usually odorless anyway. You've cleaned it 3 times - once with water and Mr. Clean, once with diluted bleach, and once with a mild solution of vinegar and water. You've even left it off and open with a fan running into it. The smell is still there. The pan under the refrig has been scrubbed too. The smell seems to be coming from the vents in the freezer. At least this seems like where the smell is the strongest. But maybe that's just because of the re-circulating cold air. You're exasperated. Any ideas? It does have any auto ice maker, but that's hooked up to the water main with a filter on it. (filter is clean).
I can think of two reasons for this. The first and most likly is electrical. Look carefully at the components especially the capaciter, it's on or near the motor. If it is leaking or out gassing, replace it. Wire corrosion can cause a wire to slowly give off fumes. Look very carefully i.e. testing meter is helpfull here. I've already expirienced this and it sure was hard to find. Less likely is a freon leak. You won't smell the freon itself but if the oil is a little burnt, that can be smelly indeed. You will need a special leak detector for that. Anyway my money is on the electrical.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
Amana sx22sw
There could be a problem with the cold control. It is a common failure item
Jun 28, 2013 | Amana Refrigerators
Funny smell coming from under my whirlpool, side by side fridge freezer. I've often noticed this smell in shops with freezer sections. The only thing I can liken it to is stale ****!! Sorry!!
the smell is urea,it is the gas they use to make the injection mouldings (plastic and foam) it is HARMLESS,but does smell like **** cos its the same gas.........(the best leather is processed with femail ****.)use male **** to accelerate your compost heap... if you think im joking try it.....
Sep 07, 2010 | Refrigerators
Warm refrigerator and freezer
May be a bad defrost timer and the evaporater is froze up with ice. Clean dust buildup from the condenser under or behind the unit. Always give the model number
May 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
There is a strong chemical burning smell coming from the fridge/freezer but it still seems to be working ok at the moment, the light is on and still feels cold, any ideas what this could be?
if the smell is very sweet something like peardrops, could be poystyrene packing. check for cable chaffing where it enters cabinet.replace mains cable completely. if mains cable outer cover is getting too hot it will smell as above WARNING polystyrene gives off cyanide gas over 120c/when burning do not inhale(only had 1 freezer melt in 30 years it was set on purpose)
Feb 07, 2010 | Refrigerators
Sweet smell from refrigerator
empty it out and wipe it all down with a solution of 1 cup of white vinegar in 4 cups of water. get all of the nooks and crannies. Then finish up that part of the job by wiping the surfaces with straight vanilla flavoring.
finally remove the lower front grill and clean the drip pan..........that should do it.
Aug 17, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Smell gas when range is not in use
i have the same problem with a 2 year old stove, it was leaking from the safty valve, that is the part that the oven burner sits on, which is located in side the broiler drower when you remove it, it's on tha back middle lower section of that opening.
Dec 08, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana Refrigerator
Dear friend,
ngfam at you service! happy to assist!
How old is the fridge ?
If its 10 years old its not worth repairing!
You will save enough money with a new fridge due to the fact that they are so much more efficient today!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Refrigerators
Refrigerators Logo
2,799 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
