Question about Meiko DV 80.2 Dishwasher
DV 80T light for 3 timer program and on/off flashing... is that cpu board problem?? thanks...
    Problem Solver:
  • 11 Answers
Are all 3 cycle lights flashing together? if so then the eeprom has blown (the little pcb fitted at 90deg to the main spuel 6 card. This component is very prone to failing where there are power cuts or surges . You will only need to replace the eeprom and not the main card but make sure power is ok before you fit new one or it may blow again.
Regards Kit
Posted on Sep 26, 2008
I just installed a Woods Digital In-wall Timer Model #59018. When I switch the power and manually turn the power on, the lights rapidly flash on and off. This is a three-way outlet and I have red, black...
3-way outlet or 3-way switch?
Woods 59018 only replaces single-pole switch, and does not work for 3-way application. Often connecting timer wrong will cause lights to blink. No harm done to lights, timer or wiring.
There are several timers that work with 3-way. In each case the timer replaces 1 switch and other 3-way switch must be rewired.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
http://waterheatertimer.org/ST01C-program.html#3-way
http://waterheatertimer.org/How-to-wire-timers.html
Gene
Aug 03, 2013 | Hardware & Accessories
Flashing lights right top of keyboard and left middle. This is no video or booting. tried new cpu doesn't fix problem.
Sad to say a common problem with the dv series in general is a bad motherboard/video card.
Easiest fix is to either send it under warranty, or order a new motherboard as the video card is integrated into the mother board.
Jun 15, 2011 | HEWLETT-PACKARD Pavilion dv5-1250us...
The timer flashes, "no-op". Refuses to turn
no-op means 'no operation.
The manual says last resort to revive non-working timer is RESET timer.
This action will delete current day setting and all programming
Hold down ON/OFF and use paper clip to push in reset button for 2 seconds.
Release reset button but keep holding ON/OFF button down until INIT flashes on screen
Then release ON/OFF button and 12:00 should display.
At this point, timer can be re-programmed.
Simple step by step shows on following link:
If timer will not accept programs, or operate after RESET, then timer has gone bad.
ST01C comes with 1 year limited warranty.
Most in-wall timers have same limited warranty.
Replacing timer:
-Advantage of ST01C is timer does not need Neutral wire to operate, and wiring can be simple.
-If you are using ST01C for 3-way switching, then easiest thing is to replace with same timer.
-If you are using timer as astronomic dawn-dusk, then replacements include EJ500, Utilitec 0192773, Aube T1034, T1070, T1072, T1073.
-If you are using timer for 7-day operations then there are numerous options:
http://waterheatertimer.org/Programmable.html#Aube
Jan 08, 2011 | Intermatic Inc. ST01C Digital In-Wall...
How do I program a Noma N1506 timer?
All Woods timers and manuals
N1506 manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 12, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How do I set the Woods N1506 timer?
N1505 timer manual:
Dec 01, 2010 | Woods Outdoor Lighting Timer
Model N1506, I need Operation instructions for this Woods Light Timer?
N1505 timer manual:
Dec 01, 2010 | Hardware & Accessories
Had a power interuption and now the timer light is flasing and the tv won't come on. Tried reset with no result. Now what?
Green timer flashing is CPU board inside booting program. This is normal after it has been unplugged and lasts for 70 seconds, normally. If it continues blinking, then there is a problem with it not being able to boot. There are bad parts inside; whether the power supply or CPU board, and possible others. It can be OK until it is unplugged/loses power, where it has to re-boot now.
May 02, 2010 | Mitsubishi WD-62725 62" Rear Projection...
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
DV 80T
this is not a cpu problem it is a key pad failure or a blown fuse
May 12, 2008 | Meiko DV 80.2 Dishwasher
Dishwashers Logo
376 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Trevor Turner
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
